Super Jet I need your SuperJet Advice!
So hey ya'll. I bought my first jetski (2017 Yamaha EX Sport) with 27 hrs on it for $4900 with a 2 jetski trailer (A steal!!) and love it. I most love riding it like an ahole at slow speeds - fast stuff I don't care for and I view as a hassle with the Wakes. Well - I have thought about a standup! I love doing all sorts of turns and stuff with the sit down 3-seater and thinking I should get standup and specifically a Yamaha Superjet.
Now I found my 2017 on a whim and it was a deal - but I'm not finding much on the Superjets but mostly the below observations:
2015-2018 are $6800-7400
2012-2015 are $5800-6500
Older than 2012 as low as 2003 are around $4000
No major changes have happened that I'd notice as a beginner to the product
People wanting more money for older models have "tons of upgrades" but I'm thinking until I do flips - do I really need them?
Am I right in my observations above? I don't want to buy a jetski and rebuy and I feel like with my 2017 Yamaha I won't have to rebuy a sitdown, its a great jetski! So I'm deciding if I want to go newer (used 2017 / 18 in my area) or get a cheapy one that's older...
Can someone give me some wise advice?
So far I have gotten:
""Other than the slight hull redesign in 2008, there have been no significant changes in Superjets since 1996. Same 701 engine. Same pump and drive design. Even the old squarenose Superjet had the same stuff for last few years of it's life.
What that means is that if you're shopping for a Superjet, the age doesn't really make any difference, unless you're buying stock and plan to keep it stock. No one does that, since stock SJs are boring and any rider can eek out tons more performance for modest amounts of upgrades.
People wanting more money for older models have "tons of upgrades" but I'm thinking until I do flips - do I really need them?​
The thing is, if you're serious about stand-ups, you're going to want the performance upgrades eventually and some of them will be huge pains to replace stock (impellers) or the demand is so high right now that you're going to pay through the nose to get them (pipes, hoods, carbs, etc). If you can get them when you buy them, you should. Things like pipes are getting harder and harder to find, so the price is just going to go up.
Unfortunately, this all means that in order to get a good SJ, you're probably going to pay for it, but even if you buy a 1996 with solid upgrades, it's going to be the same basic machine as a 2018 with the same upgrades, and it will be a lot cheaper.
Also, DO NOT get into Superjet riding if you don't want to spend time wrenching on your ski on a regular basis. If you want to get out and ride and not do regular repairs and maintenance, don't ride Superjets.""
Ignore that!! That’s such BS
I have a waveraider and an 08SJ. Both the Yamaha 701 based motor and both skis have been the most reliable watercraft I’ve ever owned. Now my SJ has tons of mods and yes it has cost me a lot and it’s been a lot of work but it’s been a fun project and I’ve done it slowly over the past 10yrs. Yes it’s not as maintenance free as it once was but I knew what I was getting into. A Stock SJ is gonna be a blast for anyone new to stand ups. Find a clean one and just ride. Buy the best you can afford! I wanted to start with a stock new ski and know exactly what I had and what it’s been through it’s whole life.
Just because you may not want to do flips you will still want the modifications if you get into riding, almost every superjet that you'll be able to find are not setup to do flips, all the mods you see to superjets are for better handling and better power, it takes alot to be able to flip a superjet and you'll most likely not find one for sale, if you are going to get into stand ups absolutely get a superjet, they are easily the most reliable standup out there and probally the most fun stock, I do recomend if you are going to get one, actually go for the most modified ski you can find in your price range, because once you get into stand ups you'll always be looking for that little bit of extra power and itll be way cheaper to buy a ski with all those mods than it would be to build a ski from bone stock
Sent from my SM-G960U using Tapatalk
Though if you do buy a modified ski make sure it's running properly and try to get a test ride or if you dont yet know how to ride one have the owner take it out for you real quick and make sure it sounds okay and runs properly, but at the same time, a stock superjet is still a blast! And you will not be disappointed.
I'm worried if I get a modified one I won't know how it's been treated - although I do agree coming from the sport bike world that it will be way cheaper, but I'm seeing a modded say 2007 for $7,100 - thats what a stock 2017 is. What do you think in that case? How much would a modded one have in it, $10,000 worth of work?
Req
SW Tenn
Some mods people do are below. This should help you address the value.
Main mods people do
B Pipe: 900 bucks
ADA Head: 250
MSD Enhancer: 325
Hooker 9/15 prop: 275
More advanced mods.
Cylinder porting: 350
Case porting: 400
Front sponsons: 300
DIY mods.
Shorten handlepole: Free
Quicksteer mod: Free, redrill location on steering nozzle.
Footholds: 100 bucks but need to glass them in
I’m probably into mine for about 8k. But that’s cuz they only cost around 6k new back in 08. Steering mod is a must on the 08+ And I just recently did the pipe and head and it was absolutely worth it. I did footholds and padded the whole tray which was a very nice upgrade as well
For reference this is what I have into mine specifically, and I would consider this pretty modified but not all out
Jm/blue top end: 725
Girdled head: 350
Factory bpipe: 450
Custom aluminum handle pole: 350
New/ rebuilt ebox: 100
Intake grate: 200
Rideplate: 150
Custom 3 part paint job: 300
Footholds: 50
Carbon hood: 575
Lowered handle pole bracket: 150
Turf: 150
Foam for tray: 100
Rebuilt and re jetted carbs and new F/A: 300
9/15 hooker prop: 350
Carbon tech reeds and reed cage: 200
Bilge: 50
Total= $4350 just in modifications
150+ hours spent on the ski
Hull modifications include
Re foamed tray
Foot holds
Reinforced engine bay and tray
Re sealed engine compartment
Hydro turf
Dual cooling
All of this was done by me including paint bringing the price down but all in all I would value my ski around 7000 just because the amount of labor and time went into this ski
  • Like
Reactions: Req
If you can find a ski for 3500-4000 with b pipe, head, impeller. Maybe msd I'd consider that a very good deal, even if it needs a little work
Buy the new one and ad mods if you feel you need them. You will always be happier with a newer cleaner unmodified reliable machine you can enjoy. For your needs the newer the better.
