- North Carolina
Well want to experiment a little with some powder coating. I have the carbs torn almost all the way down but was wandering if the throttle butterfly bushings would withstand the heat of the powder coating process(400 degrees) for 20 min. If they will not can some one explain to me the process of removing the butterfly without destroying it and being able to put it back in? I believe the screws that hold on the throttle butterfly are staked on and in my experience you cant remove them with out screwing them up. Also what is the difference between a stock set of 44s and and aftermarket set? Ive heard the aftermarket sets are more tunable. I have already removed the choke plates and will be using a primer, But what is done to a set to make them tunable?
