igni pro/blowsion pro ignition
hello all
anyone have some curves? from blowsion can you make screenshots for me? they put 4 pre- programmed on the disk they say and like to know how the timing curves are
or have some other curves for me to start with
my specs.
sxr 850
46mm
wetpipe
29cc
igni pro
95 octane
thanks for reading and replying
loco di aqua
Off Site
You are going to like that ignition, 1000 cc. I was running 30% race gas. Make sure you ramp it down at 4500. That is when detonation will start to set in. You don't need a lot of advance at idle. I am a novice so Art at jetworks is a good guy to talk to. He explained to me when detonation hits. This curve is from Blowsion. They would be a good source too, really cool guys.
IGNITECH_KEY 72
RPM_ADV 1300 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 8000 9000
ADVANCE 11 32 32 32 32 32 32 32 28 23 19 17 15 14 25
POCET_BODU 15
BASE_ADV 11
LIMITER 8500
POLARITA 2
NO_READING 0
BLOWSION SETTING
DATE:10-29-2015
19 17 15 14 25
REV LIMIT 8500 RPM
hello all
my specs.
sxr 850
46mm
wetpipe
29cc
igni pro
95 octane
loco di aqua
Off topic a little . 850cc is that considered a big bore kit how do u like it n who makes it
Also 46 mm carbs what kind
Base advance 11 for real? But great thanks i know this one is better then was in there :) this makes some sense!
Verstuurd vanaf mijn SM-G920F met Tapatalk
