- Cleveland Ohio
Does anybody make an SXR to SJ Conversion PV B-hood with triple scuppers? I was thinking if I ran a fixed-steer Lamey aquavein impeller with it and a stubby flow-control Pipe it would pull like a mofo.
Or would a cut-back zero degree d-cut flywheel with a total-loss stroker magnum valve give the same performance with better reliability?
Right now, I am only running dual lime carbon fiber freestyle sponges and a -4 degree retarded compression crank and am looking for a good, reliable (yet inexpensive upgrade) for more medium end power and higher weight.
btw...I love the new ODI texalium girdled 17 degree bars and the Skat Slip Grips!
:mischievous:
:mischievous:
