impeller removal sj
HAMMER
SKI ADDICT
It's let handed threads
Right=loose
Left=tighten
Oh yeah some long wrenches,pipe to slip over wrench (leverage) and a vice will also help.
Fought with mine to !
HAMMER
so do i put the splines of the shaft directly into a vise, and crank it down as hard as i can to stop the shaft from spinning ?
keefer
T1
Tennessee
Only if you want to ruin that expensive drive shaft. :banghead: Do like SFL said and get the proper tools before you break somthing and really get into your pocket. I have had to get some props pretty hot and use a 3ft bar on a big wrench to get them to pop. I always go back with antiseize compound when installing the new one. Good luck.
HAMMER
SKI ADDICT
ya def. need the spline tool bro.
do not put those splines with out the spline tool in a vice
Oh No No No NO!
HAMMER
