Impeller Stuck in Wear RIng
Hey Everyone,
I have a Torrent 155 Set-Back Pro and I just got an ET 1107 so I had to get a new prop. I swapped props with the guy I bought the engine from since we practically had the same setup. I installed the Torrent 155 Cutback Long Blade. When I installed the Impeller it was a little tight but spun freely. I started the ski and noticed I had some electrical issues and had to replace the starter. I replaced the starter and started the Ski and it ran then shut off. I started the ski back up and I heard a nasty sound and then the motor was locked. I pulled the front cover off hoping that the Benedix was stuck on the flywheel but I had no luck. I pulled the pump and noticed that the impeller was stuck pretty badly and would not be able to extract the impeller. I sent the pump over to Brian at Torrent to work his magic.
I was hoping for some insight.
What would cause the Impeller to get caught in the wear ring so bad if the prop I had was the same specs (Cut Back, Long Blade, Same Pump) just a different pitch?
What damage and I looking at? New Impeller, New Wear Ring, New Pump?
Without having pictures, since I had to send the pump to Brian what are the odds that at least the wear ring is salvageable? I'm sure the impeller is a lost cause because it is going to be destroyed getting removed. Just trying to estimate the damages I am looking at.
McDog
Other Administrator
Staff member
South Florida
You will be fine on stator. They can drill the shaft out at worst case scenario. Prop probably will be fine too.
Stockton
Side note: At this point it would be good to pull the flywheel and check your Woodruff key, I’ve seem them shear when the crank stops suddenly….
I guess you could also see if starts without backfiring and verify it that way too, quicker
Did u check to shaft that it was not already bent prior to putting the tighter impeller on ? It just takes little with a bent shaft if your clearance are not proper...
the impeller snags and the rest is just additional damage
