I utilized the two m6 holes in front of the engine to hang an L bracket and installed an L on the bilge with some sheet metal screws, positioned the bilge and then backdrilled the Ls together. I didn't use a base for the bilge and it is tight against the bottom of the hull.Had to use the old bilge port location the old owner did. I used a waterproof switch in the area above the battery. do you think mounting right into the top of the bilge will hurt anything. I could probably route the hose different and trim some off. thoughts?
