Blaster installing a pump shoe need some advice
Vegas
Its finanlly time I install my pump shoe so I can start riding my blaster again
I bought the watcon pump shoe any advice on installing it. I know theirs tons of grinding involved
Orlando
post a pic of the shoe. Make sure you test fit it several times before making it permanent. You want to make sure the pump seals all the way round the face of the shoe. I used a flashlight up the tunnel to check for gaps. You also want the driveshaft coming through the hull as dead center of the hole as possible. Once everything lines up, drill your holes to hold the shoe to hull and glue it in place.
If you have to grind, take off a little at a time.
