You'll probably scoop some but scoop grates work because you're moving along with the back end lower than the front. When you're on the ground, the front is the same level as the back. The grates don't actually have a shovel like scoop that sticks further than the bottom of the hull.
Sand will get in your pump. Even dragging your ski onto the beach will get a little sand inside. As long as the engine isn't running until you slosh the sand out you'll probably be ok. BUT the occasional rock in the sand will ruin you prop/pump/day.
