Intake grate length?
ND
Just wondering if there is a difference in intake grate lengths? I have a worx intake grate and I am not sure what it is for. Thought it was for a superjet because it has 2 holes on each side for mounting.
Was going to put it on my Chan but looks like it is too short.
Any help figuring out what it is for would be great.
thanks
37
Precipitation Hardened
Indy
What number is stamped on it? If there's no number, how long is the bolt pattern from center-to-center?
I think the Chan uses the longer 2008+ superjet grate.
OEM 1990~2017 SJ grates are all the same part number and bolt pattern. Length never changed. I have an old stainless Skat grate from the early 2000s on my 2016. Only major change was some companies re-pitched the scoop angle to better match the 08+ pump tunnel.
ND
Guessing it's for a sj or a blaster. It's about 13 3/4" from bolt pattern on one side to the other.
37
Indy
Looks like a WR205 for the SuperJet. It'll work on a Blaster but they porpoise less with a WR201.
