Quinc
Buy a Superjet
- California
Superjet wont rev until pump comes out of the water... I can cruise around at around 4-5k rpms but it will not rev until I break the pump loose, then she will rev and hit the full rpm range/top speed. But as soon as I get below a certain rpm I have to hop or break the pump loose to get rpms up again.
61x ported and bored 1 over
bpipe
Single 46 155/130 24psi
boyesen reeds
stock electronics
hooker 10/16
170psi
-Cleaned carb, verified pop off etc.
-Replaced fuel line and fuel filter.
-One way valve is working
-Turning the screws makes no difference
I am leaning toward reeds are bad (only 2 season old...) but figured I would see if anyone else has had this.
bpipe
boyesen reeds
stock electronics
hooker 10/16
170psi
