I just installed a double pickup MSD TL this past weekend. Wired up and running fine this weekend. Ran the battery dead. Installed fresh battery today. Was very difficult to start. Finally fired and went to ride...felt like I was running on one cylinder. Confirmed with intermittent spark on front cylinder. Rear cylinder firing regular. When I was setting plugs on head I noted that the brain was chirping with small spark noted at plug when I was dragging it across the plug hole(???). Brain was on and lanyard was installed when this happened, but it was strange nonetheless. By the end of a thousand starts with me checking plug wires were secure and wiring was all connected and grounds were in place I ran the fresh battery dead, so I quit diagnosing. When I quit, both plugs had stopped sparking with engine turning over slower and plugs out. No changes made except battery.
1. Why? Ran fine. Parked it. New battery and now trouble??
2. Causes of intermittent spark? Coil, ground, faulty S/S or TL switch?
3. Will a coil just die on you? I've never seen one just quit. I've never really had one be dead.
3. Will MSD TL stop sparking with low battery voltage (kinda like ATP Flame)?
My coils are grounded individually to one of their own mounting bolts and then a common wire splices both ground leads together and runs to the battery ground. I know the directions say each coil needs to be grounded individually to the motor...am I setting myself up for trouble with my current schematic? I know the mantra is that you can never have too many grounds, but the MSD directions don't call for extra grounds.
[COIL]------(coil mount bolt)---___________(battery ground)
