Is this Ok to run??
tor*p*do
Squarenose FTW
NW NC
this piston from my 750 is missing a small piece
there is also a little crack that goes all the way through, skirt flexes some
it should be OK?
clean up with a little steel wool, yes? :bigok:
tor*p*do
Squarenose FTW
NW NC
j/k, thats why it is in carnage.. . . . .:tomato:
anyone need a 750 case, head or cyl? . . .
FyrHazard
Ski Eat Sleep Repeat
Iowa
Haha throw that sucker back in there, you haven't gotten all the use you could out of it. Tell you what, run her real lean and try to melt through the top before the skirt snaps off. They always run the hardest before they die!! :poke:
wtf is your effing problem, man? why would you tell this person to sabotage and damage an easily salvageable piece of quality machinery like that? are you some kind of punk that gets off on this kind of stuff? HUH? ARE YA?!?!?!
oh wait.... this is a kawi....
sorry, dude..... my bad....
tor*p*do
Squarenose FTW
NW NC
motor never locked up
crank seal blew out here: http://www.x-h2o.com/threads/45788
took out bendix and shut down motor
I found this piston after the motor was torn down
cylinder, case, head were OK, original '92 crank was rough
got a new motor on the boards, 165 psi both cylinders :burnout:
