I don't know anything about the seadoo engines. What makes the seadoo 720 put out more than a kawi 750? What are the 750's doing... 80hp? Anyway, cool project.
Ok class is now in session,,,
The Seadoo engine is a rotary valve induction engine,these type engines produce more hp per cubic centimeter than any other type of two stroke engine,it is because of the rotary valve feature which provides a positive precisely timed opening and closing of the intake port.That means no back flow through the intake to disturb the incoming fuel air charge,it also means easily adjustable timing of the intake timing by changing or retiming the rotary valve itself.There are millions of the 717 engines in use it is the most reliable engine ever produced by Rotax for use in a watercraft.Stock hp is 85 hp,thats with a very restrictive intake system and exhaust,40mm carb and only 150 lbs compression.What we have here is a 46mm mikuni carb,free flowing intake system,very free exhaust and 180 lbs compression.I also took off the heavy pto and replaced it with a Kawi coupler machined to fit the Seadoo crankshaft.The Kawi big pin does put out 80 hp in a ZXI or STS,I don't think any other 750's do actually have 80 hp.The bottom line here is this ,if the whole engine pukes for about $600.00 I can have all new internals and be back up and running,I personally have never been able to break a 717 engine,this one may be the first.There are also several mods such as dual carbs,total loss ignition and larger rotary valve that I can do to this engine that will make it even faster and not affect reliability.As it is it is damn fast and should be very reliable.I went out of my way to make it easily servicable if a problem arises.The fuel tank comes out easily,as does the starter,carb, exhaust system and top end,electrical components are easily acessable in the electrical box where the battery used to reside.The only problem I did have was the starter, that was solved by drilling out the bottom hole in the front cover and installing a helicoil in the starter hole so the bolt could be acessed from the front,now the starter comes out in less than 5 minutes as can be the carb,entire engine can be out in less than 10 minutes.
