They almost always need to be ground down a bit. The shoe, not the hull.New
Hello there, im about to install my new JD shoe 155 i have 155mm skattrak pump will be using it on rickter xfs hull.. it not fitting in side the hull its bigger than the hull hole, do i need to grind the shoe or the hull ? or just the hull? please Help.
You're going to half to grind both to fit that in your xfs. Start with grinding the shoe paper thin, then grind the hull to fit. Take you time and test fit lotsNew
