Superjet 9195
Dude... you can jump that
- Salisbury, NC
Sup Fellas,
Ok so after about a year of "being too busy" I am finally putting my square back together. I have a problem, I think. I put the pump assembly in last night and even with the all the shims at the back of the pump the shaft is resting on the bottom of the hole going through the hull. ( Can you picture what I am saying?) Like the pump needs to be shimmed down more in the back to get the shaft to come up in the front into the center of the hole. The shaft does not look bent from visual inspection. I dont remember how it was when I took it apart, I do know the the bearing for that shaft needs to be replaced, cause it sound like there is a pound of gravel in it. I have tried it with no shims and pretty much all other combinations. Is this normal, should you have to pull up on the shaft to get the bearing housing into place?
Maybe it was like this before and that is why the bearing is toast.
