Jetinetics help!
So I came across this, I am assuming it is similar to msd setup... Does anyone have any experience with this system and will it be compatible with my dasa 850 62t. And is it mainly for racing or good for all around because it would go in my BOB. Any input helps thanks
yamanube
This Is The Way
Staff member
Mandalor
I ran one for a season or two on both a ported 760 with a Bpipe and a stock 61x/61x with a B pipe and it ran very well. It doesn't have the programability the MSD units have but the pre-loaded curve seems to perform well and the flywheel is crazy light. Is it equal to an MSD total loss? No. Is it better than a stock ignition with an enhancer and a lightweight flywheel? Definitely. I used to be able to get a full 3 day weekend out of a single charge on my Odessey 625 as well, has an automatic on/off programmed in so no switches to forget about or shifty module to buy.
If you do buy it, I would highly recommend spending some time on that wiring, adding loom and neatening it up.
