Jetmaniac Big Bore 781
Jetmaniac 781 big bore motor. These motors are excellently ported and make great power. Motor has about 40 hrs. Even 180/180. Comes with Mikuni 38s & adapters, Boyesen dual stage carbon reeds, and reed spacer. I can include some bed plates if needed.
Sold
e30a806f95a430f9b97834d8dcda3332.plist
I'm a little curious, are these things usually built as actual 781cc's (85.5mm) or do people usually go with 85mm (771) to leave an extra "freshen up" bore option?
Anyway, sweet motor good luck with sale.
Jcary85
Vendor Account
Glenmoore pa
Can’t believe this hasn’t sold. My 781 is a BEAST. Hits much harder then a lot of much bigger motors. This is a steal!! I have a review thread somewhere and lots of videos of flips with mine if anyone is interested.
JetManiac
Stoked
Vendor Account
orlando
http://www.x-h2o.com/index.php?threads/jetmaniac-blue-781-backflip-capable.196137/
My note to buyer of this motor: Unless the reed spacer is needed for the reeds setup to clear epoxy in intake, then remove it. Increases the case volume and decreases power off the bottom. But will still hit fine with the spacer, just even better without it. BTW, this is a $3500. package new so a smoking deal for a low hour clean used motor.
Thanks for the info. Can the reed spacer be removed, or is it used to clear the epoxied cases?
