BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO
BOGO Deals - JetManiac has gone BOGO crazy again!! Our popular BOGO sale is back for the seventh year.
Buy One, Get One at 50% off!!!
JetManiac's always popular Black Friday BOGO sale is here again this year with lots of new items added.
Also you can mix and match as well. You don't have to get 2 of the same item.
Give us your parts list, we will apply as many BOGO specials as apply and sale pricing on some other items as well. Don't miss out on our Seventh Annual BOGO sale. Sale pricing good through Monday night. All orders started by Monday night and paid by Tuesday will qualify. Some quantities are limited to stock on hand.
*For example, you can buy a hood strap kit and get a tow strap or bolt kit 1/2 off.*
Special Black Friday sale deals are also listed below the BOGO deals.
JetManiac Ratcheting Hood Strap Kits
Ratcheting hood strap kit- replaces or extra security with stock hood latch
*includes complete SS mounting hardware(bolts, washers, and nylock nuts) for both ratchet and straps.
Buy one hood strap kit for 35.90, get second one for 17.95
JetManiac Tow Strap Kits
Towing Carabiners Kit - 'Surf Tested'
These are super high quality marine grade stainless steel tow clips are manufactured by Suncor Stainless for us, and have been surf tested over many years by hundreds of freeriders.
They are stronger than most carabiners and don't have the sharp ends which will snag on ropes and webbing. They are also all stainless, unlike most carabiners which have steel pins which will rust. They are smaller and lighter than most alternatives and have much higher strength rating.
Buy one tow strap kit for 20., get second one for 10.
JetManiac Limiting Rope kit
Limiting rope kit includes:
Stainless tray loop mount and hardware, 2 Stainless carabiners, 2 styles of Stainless pole mounts, and rope kit with elastic keeper and clip to pole base area.
Buy one for 39.90, get second one for 19.95
JetManiac Factory Pipe Headpipe SS Bling Bolts
Do your factory pipe headpipe bolts look like the ones on the left?
Replace your rusty headpipe bolts with JetManiac's Stainless headpipe bolt kit.
If you have ever tried to find this bolt size locally, you know they aren't available in the US. These were sourced by JetManiac in Asia to get this rare size.
Buy one Factory Pipe bling bolt set for 24., get second one for 12.
Also on BOGO
Flywheel cover bolt kits
Mikuni carb allen bolt kits
Mikuni carb internal bolts kit
Intake manifold bolt kits
Head bolt kits
Exhaust manifold bolt kits
Any other bolt kit we have
JetManiac Bpipe and Big Bore Bpipe gasket sets
Bpipe gasket set (manifold and headpipe gaskets) 17.90
Buy one Bpipe gasket set for 17.90, get second set for 8.95
Big Bore Bpipe gasket set (manifold and headpipe gaskets) 19.90
Buy one BB Bpipe gasket set for 19.90, get second set for 9.95
Kawi 750/800 Bpipe gasket kit 17.90
Buy one Kawi Bpipe gasket set for 17.90, get second set for 8.95
JetManiac Freeride Gasket Kits
62t/61x SuperJet/Blaster dual 38 with Bpipe and a/m head custom freeride gasket kit
For Yamaha or Kawasaki
http://www.x-h2o.com/threads/...Gasket-Sets-45
Buy one gasket kit for 45., get second one for 22.50
61x/61x Single carb with Bpipe and a/m head custom freeride gasket kit
OEM crank seals set for Yamaha or Kawi
OEM crank seals set for Yamaha 650/701/760/1100/1200
Buy one Yami seals set for 44., get second set for 22.
Kawi 650/750/800 OEM genuine crank seal set 65.32 Sale 44.
Buy one Kawi seals set for 44., get second set for 22.
ADA Head O-ring kit for Yamaha or Kawi
Or Blowsion Head O-ring kit
Or Riva Head O-ring kit
Buy one Oring kit for 19., get second one for 9.50
Specify which head you have, Orings are all specific to brand and application.
Also BOGO loose dome Orings for XS, DASA, PHP, ADA, Blowsion, etc.
Also PHP, Boyesen intake manifold speed plate Orings
Wrist Pin bearings for Yamaha
Buy one pin bearing for 18.90, get second one for 9.45
Regular size for Yamaha 701/760/1100
or
Wider length for DASA, TPE, or other billet motors
MSD Boots and terminals kits
MSD boots and terminals (2 of each)
Buy one MSD boots/terminals set for 15., get second kit for 7.50
JetManiac Pump or Midshaft Rebuild Kits
NSK Pump Build/Rebuild kit (2 bearings/2 seals/o-ring)
Buy one pump rebuild kit for 39.90, get second one for 19.95
(you also can get one of each)
NSK Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips)
Buy one midshaft rebuild kit for 39.90, get second one for 19.95
Koyo Jap Oem brand pump rebuild kit (2 bearings/2 seals) 89.90 sale 59.90
Buy one pump rebuild kit for 59.90, get second one for 29.95
Koyo Jap Oem brand Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips) 54.90
Buy one midshaft rebuild kit for 54.90, get second one for 27.50
JM floating lanyards
Floating Yamaha a/m lanyards 13. (red, yellow, black, or silver)
Floating Kawasaki a/m lanyards 13. (red, black, or neon green)
Buy one lanyard for 13., get second one for 6.50
More deals in posts below....
Also on BOGO
Head bolt kits
or
