JetManiac Black Friday week thru CYBER MONDAY> JetManiac BOGO Sale Black Friday BOGO
JetManiac
Stoked
Vendor Account
orlando
JetManiac Black Friday week sale is on!
This year it has especially hard to find deals, and to find inventory to sell, but JetManiac has been working hard for months to deliver for you. As always more deals will be dropping all week and our BOGO sale is on also.
BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO
BOGO Deals - JetManiac has gone BOGO crazy again!! Our popular BOGO sale is back for the ninth year.
Buy One, Get One at 50% off!!!
JetManiac's always popular Black Friday BOGO sale is here again this year with lots of new items added.
Also you can mix and match as well. You don't have to get 2 of the same item.
Give us your parts list, we will apply as many BOGO specials as apply and sale pricing on some other items as well. Don't miss out on our Ninth Annual BOGO sale. Sale pricing good through Cyber Monday night. All orders started by Monday night and paid by Tuesday will qualify. Some quantities are limited to stock on hand.
**For example, you can buy a hood strap kit and get a tow strap or bolt kit 1/2 off.*
Special Black Friday sale deals are also listed below the BOGO deals.
JetManiac Ratcheting Hood Strap Kits
Ratcheting hood strap kit- replaces or extra security with stock hood latch
*includes complete SS mounting hardware(bolts, washers, and nylock nuts) for both ratchet and straps.
Buy one hood strap kit for 41.90, get second one for 20.95
JetManiac Tow Strap Kits
Towing Carabiners Kit - 'Surf Tested'
These are super high quality marine grade stainless steel tow clips are manufactured by Suncor Stainless for us, and have been surf tested over many years by hundreds of freeriders.
They are stronger than most carabiners and don't have the sharp ends which will snag on ropes and webbing. They are also all stainless, unlike most carabiners which have steel pins which will rust. They are smaller and lighter than most alternatives and have much higher strength rating.
Buy one tow strap kit for 20., get second one for 10.
JetManiac Handlepole Limiting Rope kit
Limiting rope kit includes:
Stainless tray loop mount and hardware, 2 Stainless carabiners, Stainless pole mount, and rope kit with elastic keeper and clip to pole base area.
Buy one for 39.90, get second one for 19.95
JetManiac Factory Pipe Headpipe SS Bling Bolts
Do your factory pipe headpipe bolts look like the ones on the left?
Replace your rusty headpipe bolts with JetManiac's Stainless headpipe bolt kit.
If you have ever tried to find this bolt size locally, you know they aren't available in the US. These were sourced by JetManiac in Asia to get this rare size.
Buy one Factory Pipe bling bolt set for 24., get second one for 12.
Also on BOGO
Flywheel cover bolt kits
Mikuni carb allen bolt kits
Mikuni carb internal bolts kit
Intake manifold bolt kits
Head bolt kits
Exhaust manifold bolt kits
Most any other bolt kit we have
JetManiac Bpipe and Big Bore Bpipe gasket sets
Bpipe gasket set (exhaust manifold and headpipe gaskets) 17.90
Buy one Bpipe gasket set for 17.90, get second set for 8.95
Big Bore Bpipe gasket set (manifold and headpipe gaskets) 19.90
Buy one BB Bpipe gasket set for 19.90, get second set for 9.95
Kawi 750/800 Bpipe gasket kit 17.90
Buy one Kawi Bpipe gasket set for 17.90, get second set for 8.95
JetManiac Freeride Gasket Kits
62t/61x SuperJet/Blaster dual 38 with Bpipe and a/m head custom freeride gasket kit
For Yamaha or Kawasaki
http://www.x-h2o.com/threads/...Gasket-Sets-45
Buy one gasket kit for 45., get second one for 22.50
61x/61x Single carb with Bpipe and a/m head custom freeride gasket kit
OEM crank seals set for Yamaha or Kawi
OEM crank seals set for Yamaha 650/701/760/1100/1200
Buy one Yami seals set for 44., get second set for 22.
Kawi 650/750/800 OEM genuine crank seal set 65.32 Sale 45.
Buy one Kawi seals set for 45., get second set for 22.50
ADA Head O-ring kit for Yamaha or Kawi
Or Blowsion Head O-ring kit
Or Riva Head O-ring kit
Buy one Oring kit for 19.90, get second one for 9.95
Specify which head you have, Orings are all specific to brand and application.
Also have Head Oring kits for RIVA, DASA, PHP, and Blowsion
Also BOGO loose dome Orings for XS, DASA, PHP, ADA, Blowsion, etc.
Also PHP, Boyesen intake manifold speed plate Orings
Wrist Pin bearings for Yamaha or Kawi
Buy one pin bearing for 18.90, get second one for 9.45
for Yamaha 701/760/1100/1200nonPV
or Kawi
MSD Boots and terminals kits
MSD boots and terminals (2 of each)
Buy one MSD boots/terminals set for 15., get second kit for 7.50
JetManiac Pump or Midshaft Rebuild Kits
NSK Pump Build/Rebuild kit (2 bearings/2 seals/o-ring)
Buy one pump rebuild kit for 39.90, get second one for 19.95
(you also can get one of each)
NSK Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips)
Buy one midshaft rebuild kit for 39.90, get second one for 19.95
Koyo Jap Oem brand pump rebuild kit (2 bearings/2 seals) 89.90 sale 59.90
Buy one pump rebuild kit for 59.90, get second one for 29.95
Setback Koyo MAG Pump Build/Rebuild kit (2 Koyo bearings/2 seals) 149. sale 109.95
Buy one pump rebuild kit for 109.95, get second one for 54.98
Koyo Jap Oem brand Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips) 59.90
Buy one midshaft rebuild kit for 59.90, get second one for 29.95
More deals in the following posts below....
JetManiac
Stoked
Vendor Account
orlando
JM Billet Accessories
*Pissers, Bilge Outlets, Bow Eyes, Throttle Wheels
Billet Water Bypass 'Pissers'
ADA billet 45deg water bypass (pisser) 3/8" 12.
(silver, black, blue, red, orange or green)
(green was discontinued by ADA, so only a few left)
Buy one billet pisser for 12., get second one for 6.
ADA billet 90deg water bypass (pisser) 3/8" 12.
ADA billet straight water bypass (pisser) 3/8" 12.
(silver or black)
Billet Bilge outlets
ADA Billet bilge outlet
(black, silver, blue, red or orange in straight or 45 degree)
Buy one billet bilge outlet for 17., get second one for 8.50
Billet Yamaha Bow Eyes
ADA Yamaha billet Standard length bow eye $12.
-in black, silver, red, blue, or orange(not pictured)
-Use same fitting for front or rear
Buy one billet bow eye for 12., get second one for 6.
ADA Yamaha billet long bow eye fitting $18.
(in black, silver, red, or blue)
-Perfect for trays with thick padding
Buy one billet long bow eye for 18., get second one for 9.
Kawasaki billet bow eyes
ADA Kawasaki billet Standard length bow eye for Kawasaki $12.
Billet throttle wheels
Billet throttle wheels for Mikuni carbs
Buy one billet throttle wheel for 24., get second one for 12.
Bpipe, Dry pipe, PFP pipe couplers
Buy one Bpipe or Dry pipe silicone coupler for 19.90, get second one for 9.95
Or
Buy one Power Factor Pipe PFP Heavy Duty coupler for 26., get second one for 13.
(Much beefier than the coupler that comes as standard with PFP, TNT)
155mm wear ring to shoe seals
155mm Pump Seal (wear ring to pump shoe) new a/m OEM style
Buy one 155mm pump seal for 39.90, get second one for 19.95
Riken Yamaha Piston Rings
Riken Japanese OEM style piston rings 81, 81.5, 82, 84, 84.5, or 85mm
-fit OEM yamaha, ProX, WSM, and other pistons that are OEM compatible
-set of 2 rings for 1 piston
Buy one Piston ring set for 25., get second set for 12.50
JM Individual Gaskets
Buy one gasket, get the second for half price!
JetManiac Big Bore Throttle Cables
Big and beefy! Are you sick and tired of constantly breaking, kinking, hard to pull Yami sized and priced throttle cables?
These cables are 'large and in charge.' Super sized outer jacket with same sized center cable equals easy to pull. Butter smooth throttle control!
MANIAC cables are Kawi sized so no more need for a 'Yami adapter' for your a/m finger throttle. Your carb mounting bracket will require enlarging the slot or hole to fit this big snake of a cable, but you will get a laugh tightening your new cable ends with a 14mm wrench instead of a 10mm size.
Cable has a larger throw which will require moving your throttle bracket downward or use of a carb throttle wheel. If you have a standard RN superjet dual 38 setup, all you need to do is move the throttle bracket that is bolted on the top of the intake manifold. Reattach the bracket on the bottom of the intake manifold after enlarging the cable slot and you are go to go.
Quality Stainless Steel ends and construction. 1 year MANIAC warranty-covers center pull cable breakage.
Buy one BB throttle cable for 33.95, get second one for 16.98
**Only the longer BB throttle cable in stock.
ADA head billet domes
ADA domes 701/33, 34, 35, 37cc
ADA domes 760/35, 36, 37, 38cc
Buy one ADA yamaha dome for 44.95, get a second one for 22.48
ADA flame arrestor to carb adapters
ADA SuperJet 38mm carb to flame arrestor adapter 16.99
Buy one for 16.99, get second for for 8.50
**ADA Racing billet aluminum carb adaptors fit any standard flame arrestor with a 2-3/4 inch mounting diameter.
ADA 44mm carb to flame arrestor adapter 16.99
ADA 46mm carb to flame arrestor adapter 16.99
**ADA Racing billet aluminum carb adaptors fit any standard flame arrestor with a 2-3/4 inch mounting diameter. Fits Super BN Mikuni 4 bolt carbs. Includes mounting bolts.
index.php
ADA billet Kawi 800 carb to flame arrestor adapter 16.99
Billet aluminum air filter adaptor for the Mikuni 40mm carb. Fits the stock carb on all Kawasaki SXR800's. Adaptor has a 9.5 degree taper with a 48.5mm exit hole diameter and fits flame arrestors with a 2-3/4" mounting diameter.
JM floating lanyards for Yamaha or Kawi
Floating Yamaha a/m lanyards 13. (red, yellow, black, or silver)
Floating Kawasaki a/m lanyards 13. (red, black, or neon green)
Buy one lanyard for 13., get second one for 6.50
  • Like
Reactions: KMN
JetManiac
Stoked
Vendor Account
orlando
Silicone Bpipe chamber to waterbox elbow and 90degree hoses
Silicone coupler for Factory Pipe 45deg -SJ chamber to RN or JM waterbox 39.90
(Black, Red or Blue)
Buy one for 39.90, get a second one for 19.95
Silicone coupler for Factory Pipe 45deg -SJ chamber to XMetal or H2O designs waterbox 39.90
(these have smaller inlet than OEM RN waterbox)
(Black or Blue)
Silicone coupler for Factory Pipe 45deg -SJ chamber to SN waterbox 39.90
Blaster Factory Pipe mod chamber to waterbox 90deg coupler 39.90
JM Adjustable Foothold and Ebox rear mount bling washers
Adjustable Foothold and Ebox rear mount bling washers 3.49/ea
Buy one bling washer for 3.49, get a second one for 1.75
Temp strips
Temp strips (3pack) 19. sale 15.
Buy one pack for 15., get a second pack for 7.50
-for monitoring cyl head, chamber and waterbox water temperatures
PFP water filters
PFP water filters -reg. 19.50 sale 18.
Buy one for 18., get a second one for 9.
JM Stainless shims kits
JM Motor stainless shims kit
Buy one kit for 25., get a second one for 12.50
JM Pump stainless shims kit
Buy one kit for 19., get a second one for 9.50
PV rebuild kits
Power Valve Rebuild Kit
(PV gasket, bellows, upper spring, and lower spring)
Buy one kit for 32.90, get a second one for 16.50
Brass hose fittings
Brass fittings for dual cooling on manifold, pump, head
3/8" hose 90deg fittings
Buy one for 5., get a second one for 2.50
1/2" hose 90deg fittings
Buy one for 6., get a second one for 3.
UFO Hull Mounts
JM UFO Std. 6mm SS hull mount 25./6 pack sale 20. BOGO 2nd 6pack to 10.
(base plate 38mm diameter across)
Perfect for gas tank, battery, waterbox, or pipe strap hook mounting to hull. Also can be used for mounting TL plates
and eboxes. Epoxy directly to hull. Marine grade 316 stainless steel construction.
(With ss mounting hardware for hook)
JM UFO Std. 6mm SS hull mount 6./ea BOGO 2nd one to 3.
Yamaha OEM style fuel filters
Yamaha OEM style fuel filter 9.50
Buy one filter for 9.50, get second for for 4.75
Primer kits
Dual carb primer kit (plunger or bulb primer)
Buy one dual carb primer kit for 34.90, get second one for 17.45
Buy one dual carb primer kit for 29.95, get second one for 14.95
JM Tow Loop Front - Stainless steel throughhull design
Stainless front tow loop throughhull fitting for a/m and custom hulls $15.90
(marine part, designed for towing, load rating of 1500lbs, includes stainless front and rear backing plates)
Buy SS front tow loop for 15.90, get second one BOGO for 7.95
Fuel tank check valves
Buy one fuel tank check valve for 7.90, get second one BOGO for 3.95
Trim cable to hull tube rubber boot seal
Buy one trim tube seal for 6.90, get second one BOGO for 3.45
(std size fits approx 5/8" OD trim tubes)
(larger size fits approx 3/4" OD trim tubes)
JetManiac Mikuni carb bolt kits
JetManiac allen head stainless replacement bolt kit for Mikuni SBN carb $9.90
Replace those crappy easily stripped carb screws with JetManiac's stainless steel allen head bolt kit for Mikuni carbs. JM kit includes:
4 SS allen bolts for diaphram cover
4 SS allen bolts for fuel pump with flat and lock washers
(or custom bolts for slave carb on dual 38 setup)
Buy one JetManiac bolt kit for 9.90, get a second kit for 4.95
Mikuni genuine OEM Internal replacement carb screws kit of all 5 screws $6.95
Buy one JetManiac internal bolt kit for 6.95, get a second kit for 3.48
More deals in post below....
JetManiac
Stoked
Vendor Account
orlando
Black Friday Special Deal 1: Solas 9/15 and 10/16 Impellers
Solas had a price increase in October, so JetManiac make a big purchase just before the price increase, and also negotiated a volume discount.
Solas 9/15 144 big hub/concord freeride impeller $309. Black Friday sale $229.
- Impeller includes rubber nose seal, and Solas impeller tool.
- fits all Yamaha 144mm pumps. SuperJet 1990-2020 and WaveBlaster 1 1993-1996.
Solas 10/16 144 big hub/concord freeride impeller $309. Black Friday sale $239.
** Quantities are limited on these.
Black Friday Deal 2: ADA nongirdled head kits
Wow those look purdy!
Silver ADA nongirdled head kit for Yamaha 701/760 $300. Black Friday Sale $259.
(includes ADA nongirdled head shell, 2 open box/demo ADA 701/35cc or 760/38cc domes or your choice if in stock, Orings, and brass water fittings)
Optional add:
JM bling allen cylinder head stainless bolt kit (10bolts/washers) $29. Sale 18.
Black ADA nongirdled head kit for Yamaha 701/760 $300. Black Friday Sale $259.
Optional add:
Black Friday Deal 3: ADA takeoff girdled head kit
ADA girdled head kit complete for Yamaha $385. Black Friday Sale $319.
(includes Silver demo/takeoff ADA girdled head shell, new girdle kit, 2 new 701/35cc, 760/38cc or other sized domes, orings, hardware)
Optional add:
Black Friday Deal 4: Jet Dynamics intake grate SJ, B1
Jet Dynamics SJ/B1 intake grate $75.
This is a clean used intake scoop grate for SuperJet 1990-2020 or WaveBlaster 1993-1996. It is not totally straight. JD intakes are great performance, but castings can be 'off', and need shimming/washers to sit straight. Or can be bent straight. This one is clean but looking crooked so priced accordingly.
JetManiac
Stoked
Vendor Account
orlando
Black Friday Deal 5: VForce carbon reeds/cages
V-Force 2 Reed Cages and Reeds
The V-Force 2 Reed Valve uses a double row cage design for additional flow at all RPMs. Reed stops and rubber over-molded cages extend reed life and eliminate petal distortion. Specially developed carbon fiber reeds offer the ultimate in response and durability. The V-Force increased flow results in significant horsepower gains with freestyle pulling torque and broader peak horsepower...
Open up and Say 'AHHH!' Let your motor breathe with two rows of reeds instead of one.
VForce 2 mounted on stock/oem intake manifold for dual 38's. Also fit with stock/oem dual 44 manifolds and most a/m manifolds as well.
We have used VF2's in stock 701/bpipe setups and also in ported 701 and Big Bore ported 781's with excellent results for freestyle.
VForce2 Reeds/Cages for Yamaha 62t/64x motors $259. Black Friday sale $229.
(2 Cages with carbon reeds, gasket, instructions)
VForce3 Reeds/Cages for Yamaha 62t/64x motors $259. Black Friday sale $229.
(2 Cages with carbon reeds, 4 reed gaskets, instructions)
JetManiac
Stoked
Vendor Account
orlando
Thanks for all of your orders, and patience. Working on invoices, questions, and shipping. As long as you messaged by today, your order will be under the sale pricing.
