Engine JetManiac/Blue ported 61x freestyle motor
JetManiac
Stoked
Vendor Account
orlando
This is a newly built 61x/61x 718cc freestyle motor ported and built by Blue/JetManiac. It is designed like all of our motors to offer the most freestyle low end power for the least money with the best reliability. Some prefer the easy tuning and lower cost of the 61x single carb motor. We have best building these for years with lots of satisfied customers.
61x cases and cylinder- cylinder is freestyle ported, bored to 82mm and exhaust/head decked
New Pro-X top end with new pistons, rings, and wrist pin bearings
New Rebuilt OEM Crankshaft by SBT with all new rods and bearings, then trued and welded, includes 1 year no fault warranty
New engine cylinder gasket
New OEM crank seals
Sandblasted and then bead blasted, painted and baked on beautiful black satin finish
*New carb jets and spring for oem 44 single carb included, and carb tuning specs included
*Engine installation and break in instructions included
These motors rip! They offer the most freestyle power for your dollar.
ADA head and complete intake/carb setup package available.
*We can also rebuild your motor into one like this or trade-in your core motor (crank, cases, cylinder) with usable parts for credit off this motor.
Freestyle Ported 61x Short block $1948.
*No core needed.
JetManiac
Stoked
Vendor Account
orlando
Intake/carb option
Add Complete JM rebuilt single carb and intake package installed:
Complete single carb intake package 106.
(Mikuni 44mm OEM carb, 61x intake manifold, OEM reeds/cages/reed plate, and OEM throttle backet)
Install/build intake kit 99.
(rebuild/inspect carb, remove choke, install primer fittings, rejet/spring, pressure test carb and calibrate popoff, set initial carb settings, bead blast and paint intake, install intake/reeds/carbs with new gaskets)
Mikuni genuine OEM carb rebuild kit 58. Sale 48.
Mikuni genuine OEM N&S 21.
SS allen carb bolt kit 10.
61x carb/intake gasket kit 15.
Total intake package 299.
Hey Chris! I ride with Jd Hunt from the fx mafia,and he suggested for me to get in touch with yall. Looking for a 61x motor,carb and b pipe for my Fx1,and a few other goodies. Would you be able to suggest some things of yours? Thx Victor
JetManiac
Stoked
Vendor Account
orlando
PM sent.
So does the shortblock come with the head? And how much credit will a complete stock 61x shortblock get me. I tore it down and the main bearings are a little rough and the cylinder walls have a little light surface rust. Has a Westcoast head.
JetManiac
Stoked
Vendor Account
orlando
PM sent.
I have all summer on one of these motors. They are AWSOME !! You cant go wrong with Chris. He does what he says, on time and the best part is the motor runs great, no issues. Everything from idle to full throttle.
Awesome Motor..
Definitely recommend JETMANIAC.....
JetManiac
Stoked
Vendor Account
orlando
Awesome Motor..
And Blue.
Tampa, FL
Hey jetManiac, Looking to trade in my working sj 650 motor and grab a 718. Can you send me a price. Also, i'm in Tampa. Do you guys have a storefront/workshop? Thanks
hello jetmaniac i am interested in the 718 61x single carb setup you have for sale. Since i have absolutely no idea how to use this sight can you pm and give me some more information on the engine. Thanks casey
I have a good core to send in what would this build run me? Please include the carb rebuild as well.
