JetManiac Exhaust and Cooling Shop: Factory Pipe Bpipe Parts, Pissers, Hoses, Waterline, fittings
JetManiac
Stoked
Vendor Account
orlando
JetManiac's Exhaust and Cooling parts shop
Exhaust gaskets
U.S. made high quality SS reinforced gaskets
Factory Pipe headpipe gasket $9.95/ea or 3 for 9.49/ea
(Stock FP headpipe gasket 47mm)
Factory Pipe Big Bore headpipe gasket $10.95/ea or 3 for 9.95/ea
JetManiac has big bore headpipe gaskets for all your bored pipes!
Big Bore B-pipe headpipe gasket is about 51mm
Factory Pipe/Kawi/Coffman sizzler 45mm headpipe gasket 9.95/ea
62t exhaust manifold gasket $14.95 sale 9.95 (top in pic)
62t with 8mm helicoiled 61x size holes 12.89
61x exhaust manifold gasket $14.95 sale 9.95 (bottom in pic)
650/6m6 exhaust manifold gasket $12.95 sale 9.89
JetManiac Factory Pipe B-pipe gasket set $19.90
FP headpipe gasket and Yamaha exhaust manifold gasket (61x or 62t)
Riva red pipe headpipe gasket $14.99 sale 12.89
Coffman 4 bolt headpipe gasket 9.49
Pro-Tec 4 bolt headpipe gasket 9.49
Coffman sizzler 3 bolt headpipe gasket 9.49
index.php
Kawi 750/800 Bpipe gasket kit 18.90
Kawi 650/750/800/900/1100 exhaust gaskets also in stock.
Exhaust Hardware/Bolts
JetManiac
Factory Pipe Headpipe SS Bling Bolts
Do your factory pipe headpipe bolts look like the ones on the left?
Replace your rusty headpipe bolts with JetManiac's Stainless headpipe bolt kit.
If you have ever tried to find this bolt size locally, you know they aren't available in the US. These were sourced by JetManiac in Asia to get this rare size.
Bpipe headpipe allen stainless bolt kit $19.95 (on right side in pic above)
* 3 Stainless Allen head headpipe bolts, SS flat and lock washers)
Bpipe 61x exhaust manifold stainless bolt kit 19.90 (on left side in pic above)
* 6x stainless allen shorter bolts with washers
* 2x JM special shorter small head ss bolts for top middle of mani
Bpipe special stainless 10mm headed bolts 5.95/ea sale 4.95
* for the hard to reach and tighten top center 2 Bpipe manifold bolts
WAX headpipe bolt kit (much longer than Bpipe bolts) $24.95
KAWI longer Bpipe stainless headpipe bolt kit $19.95
PFP, RRP, TNT pipe SS allen exhaust manifold bolt kit 19.90
* 4x longer allen stainless bolts/washers for manifold ends
* 2x shorter allen stainless bolts/washers for manifold top center
* 2x special shorter small head stainless bolts for bottom middle of mani, hard to tighten location
61x exhaust manifold bolt kit OEM clean, used 9.90
62t exhaust manifold bolt kit OEM clean, used 13.90
M8 long helicoils 2.25
* for 62t 701 or 760 cylinder to mani M10 threads to convert to 61x M8 bolts
Couplers and Exhaust hoses
Bpipe coupler
Bpipe Silicone Coupler -Factory Pipe Bpipe headpipe to chamber $26. sale 19.95
(Blue, Black or Red)
New JM Bpipe HD coupler clamp 10.95
(These clamps have one of the highest clamping force ratings of all worm gear style clamps due to the fine thread pitch and riveted housing. The non-perforated band with rolled edges eliminates hose damage while increasing clamping force.)
JM Coupler install Tech Tip:
http://www.x-h2o.com/index.php?threads/tech-tip-bpipe-exhaust-coupler-installation.156252/
Dry pipe Silicone Coupler -Factory Pipe Dry Pipe headpipe to chamber 24.90
(all- Types 4, 8, or 9)
Coffman large chamber coupler 27.90
HD Yami coupler clamp for Coffman-used OEM 6.90/ea
Coffman smaller headpipe to chamber coupler 16.90
ProTec pipe HD coupler 25.95
Power Factor Pipe, TNT Heavy Duty mani to chamber coupler 28.90
(Thicker and beefier than std PFP coupler)
PFP genuine HD mani to chamber stainless clamp 10.95
PFP chamber to waterbox silicone coupler hose 16.
Chamber to Waterbox hoses
Silicone coupler for Factory Pipe 45deg -SJ chamber to RN or JM waterbox 39.90 sale 29.95
(Black, Red or Blue)
Silicone coupler for Factory Pipe 45deg -SJ chamber to XMetal or H2O designs waterbox
(these have smaller inlet than OEM RN waterbox) 39.90
Silicone coupler for Factory Pipe 45deg -SJ chamber to SN waterbox 39.90
OEM used hose elbow 45deg -bpipe chamber to waterbox 19.
Blaster Factory Pipe mod chamber to waterbox 90deg coupler 39.90
Blaster Bpipe limited chamber to U return pipe silicone coupler 13.
Waterbox to exhaust outlet -Long hose
Silicone Long exhaust hose -waterbox to bulkhead outlet 109.95
(Black, red, green, orange or blue)
OEM used Long exhaust hose -waterbox to bulkhead outlet 104.80
Waterboxes
JetManiac lightweight SuperJet and standup ski waterbox $369. sale 339.89
Details here:
http://www.x-h2o.com/index.php?threads/jetmaniac-waterbox.181445/
RRP aluminum SJ waterbox 225.90
JM modded 30.
index.php
JetManiac B1 waterbox
$419.90 sale 386.90
Details here:
http://www.x-h2o.com/index.php?threads/jetmaniac-waveblaster-waterbox.186284/
JetManiac waterbox for laydown pipe -PFP, RRP, TNT $379. sale 359.89
RRP chamber to JM waterbox reducer adapter 14.95
RRP waterbox EVA pad for waterbox shape to contour bottom of waterbox 24.95
PFP laydown waterbox 249.
Waterline and fittings
3/8" T waterline nylon fitting 3.50
(needed for FCV install)
3/8" Y waterline nylon fitting 3.50
3/8" x 1/4" x 3/8" T waterline nylon fitting 4.95
3/8" to 3/8" waterline elbow 90deg nylon fitting 2.50
1/2” to 3/8” waterline reducer fitting 3.49
1/2" T waterline nylon fitting 3.49
1/2" x 3/8" x 1/2" T waterline nylon fitting 4.95
Translucent blue 3/8" water line 1.79/ft
Translucent green 3/8" water line 2.99/ft
Black or blue silicone 3/8" water line 2.99/ft.
Hose clamps for 3/8" waterline 2.19/ea
10pack 1.95/ea
(Marine grade all stainless steel clamps, US made)
Black silicone 1/2" water line 3.09/ft.
Spray bar for water injection 39.95 sale 37.89
Water filter for PFP pipe 19.90
Water strainer -Inline 3/8" waterline filter 28.75
Brass fittings for use on manifolds, pumps, heads
90 degree 3/8" hose fitting 5.49
90 degree 1/2" hose fitting 5.95
Straight 3/8" brass hose fitting 3.95
Straight 1/2" brass hose fitting 4.95
Rare 45deg brass hose fittings
3/8" 9.80
1/2" 10.90
Brass hose blockoff plug 2.95
Universal inline flush kit 20.90
Flush kit for Yamaha OEM SJ, Blaster pipe mount 24.80
Flow Control Valves
Flow Control Valves
Flow Control Valve dries out the waterbox at low rpm for more low end power for freestyle or racing.
JetWorks FCV red Std adjustable red flow control valve 49.95
(uses different thickness included washers to adjust)
JetWorks FCV blue Pro adjustable flow control valve 54.95
(screw valve body in/out to adjust)
Water Restrictors
JetWorks
screw to adjust flow water restrictor 33.95
JetWorks new style water restrictor 33.99
(with 3 delrin inserts)
OEM throughhull waterline fitting(clean, used) 3/8" 8.90
OEM throughhull waterline fitting(clean, used) 1/2" 11.90
Exhaust mounts -Lord mounts, ProTec mounts
Short (1" rubber section)-male to female 29.90
(Blaster limited and mod bpipe)
Short (1" rubber section)-double male 29.90
(Blaster mod bpipe, Kawi 750SX)
Tall (1.5" rubber section)-male to female 52. sale 38.90
(Blaster limited bpipe, Superjet FP Dry pipes)
Flywheel cover Lord mount stainless bracket 39.95
Coffman or ProTec/small 8mm exhaust mount rubber insert 8.95
Coffman or ProTec 8mm pipe mount washer 8.95
Bpipe headpipe adjusters
Bpipe Headpipe std size replacement adjuster screw kit 27.50
Bpipe Headpipe std size T-handle replacement adjuster screw kit 32.50
Oversize Bpipe headpipe replacement adjust screw kit 39.50
(includes drill bit, tap, oversize hardware, and instructions)
Oversize Bpipe headpipe replacement adjust screw 9.89/ea
JetManiac
Stoked
Vendor Account
orlando
Bypass fittings aka pissers
ADA billet 45deg water bypass (pisser) 3/8" 14.95
(silver, black, blue, red, orange or green)
ADA billet 45deg BLACK water bypass (pisser) 1/2" 16.95
ADA billet 90deg water bypass (pisser) 3/8" 13.95
ADA billet straight water bypass (pisser) 3/8" 13.95
(silver or black)
Thrust low rider 3/8 bypass fitting (pisser) 19.89
Bpipe Carb Jet Kits
Pilot/main jets/Popoff spring kit for oem dual 38s $29.80
Pilot/main jets/Popoff spring kit for oem single 44 $15.90
JetWorks late model dual38 carb adjuster T handles 13.95ea.
Other carburator and fuel related parts:
http://www.x-h2o.com/index.php?thre...rb-parts-primers-filters-intake-reeds.144171/
Power Factor, RRP, TNT wraparound/laydown pipes and parts
Power Factor Pipe
complete exhaust system with waterbox 1,799.
* includes PFP exhaust manifold, PFP new style 3 Oring stronger chamber design, PFP waterbox, PFP silicone couplers, HD clamps, 4" and 2" foam chamber blocks, FCV, misc hardware and waterline)
RRP Ninja Carbon Fiber Exhaust System 1,995.
* includes RRP exhaust manifold, RRP carbon exhaust chamber, RRP laydown pipe waterbox, RRP silicone hump exhaust couplers(2), clamps, foam support block, water filter, misc parts
PFP couplers
Power Factor Pipe, TNT Heavy Duty mani to chamber replacement coupler 26.
PFP Orings
Factory Pipe, PFP, RRP Dry Pipe large Oring 4.
PFP new style chamber double Oring on flange 4.
PFP 3 new style chamber O rings kit 12.
RRP couplers
RRP manifold to carbon chamber hump coupler 75.89
RRP carbon chamber to waterbox hump coupler 60.89
61x exhaust manifold gasket 8.95
62t exhaust manifold gasket 8.95
SS allen PFP, RRP, TNT pipe exhaust manifold bolt kit 19.90
(new SS allen 4 longer, 2 shorter than stock with washers, and 2 special smaller PF stainless bolts)
More people are also running their PFP dry pipe as a wet pipe and need the parts to setup and tune it as a wet pipe so JetManiac is stocking what you need.
Brass Spray nozzle for water injection 34.95
Temp strips (3pack) 19. sale 15.
Temp strips (6pack) 38. sale 28.
-for monitoring cyl head, chamber and waterbox water temperatures
Factory Pipe for PFP in line water filter 17.90
Mikuni main jets (sizes 30-165) for pipe tuning
Plug for PFP chamber water jacket fittings 3.
JetWorks Adjustable water restrictor 25.
(screw adjust to any flow setting)
JetWorks new style water restrictor 32.99
(include 3 different delrin inserts)
index.php
Brass in line jet holder 15.
index.php
Water strainer -Inline 3/8" waterline filter 24.75
Clear fuel filters 6.49
-often used after strainer for extra protection
index.php
Foam riser block for Power Factor or RRP Pipe
Tall 4" block 19.95
Short 2" block 12.95
Rubber straps, hull strap hooks, and UFO hull mounts for pipes:
http://www.x-h2o.com/index.php?thre...terbox-battery-misc-straps.61807/#post-102353
2.5" to 2.5" hose coupler 16.90
Silicone 2.5" to 2" reducer coupler 14.95
Mn
Jetmaniac. I believe I sent you a pm on a 62t exhaust manifold gasket I need as well as a start button and tether stop button. I'd also like the red jet works restrictor for my water lines. Forgive me as I'm unfamiliar with this site and how to order and message etc
JetManiac
Stoked
Vendor Account
orlando
PM sent.
loictahiti
Hi Chris
Did you have special silicone hose for XFS from waterbox to hull outlet ? Yellow mark
Or two 45º silicone coupler with aluminium hose between....or an another thing? Red and blue mark
Thanks let me know
