- Newport News, Virginia
So I'm trying to help a buddy get his blaster together. Previously it was a 61x with r&d head, factory pipe, water box, SBN 44 single carb.
Now it has an ADA girdled head, and ported cylinders.
When it was first started up it ran alright until it hit the high speed jet and it fell on its face. But now, it's all sorts of messed up.
Replaced about everything in the ebox and the stator.
Looking into the carb you can see the fuel dripping into the carb at idle. I closed the screws all the way, and same thing. So I'm thinking pop off is too low?
Anyone running a similar setup? Also a good SBN 44 carb was taken off another 61x and it did the same thing. Only difference in skis was this one has ported cylinders.
