Jetting for SXR with these mods
BombThreat
'Diggity
Johnstown, NY
The ski is a 2004 and stock 40mm Mikuni's. I was wondering if you guys could help me figure out what kind of jetting would be best for rec riding with these mods.
-Dry Pipe
-JSU Girdled head 27cc domes (if the compression is too high, can I change the base gasket to lower it?)
-Vilder Flywheel 5 degree advance built in. (Since this a older flywheel; pre-sxr's does the 5 degree actually work on the 04's? Im really not sure)
- Pro-K filters w/ outterwears
The elevation is approx. 750feet were the ski will be run.
