JetManiac Black Friday sale is on!
This year it has again been especially hard to find deals, as well enough inventory to sell, but JetManiac has been working hard for months to deliver for you.
BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO
BOGO Deals - JetManiac has gone BOGO crazy again!! Our popular BOGO sale is back for our TENTH year, WOW!
Buy One, Get One at 50% off!!!
JetManiac's always popular Black Friday BOGO sale is here again this year with lots of new items added.
Also you can mix and match as well. You don't have to get 2 of the same item.
Give us your parts list, we will apply as many BOGO specials as apply, and apply any available sale pricing on some other items as well. Don't miss out on our Tenth Annual BOGO sale. Sale pricing good through Cyber Monday night. All orders started by Monday night and paid by Tuesday will qualify. Some quantities are limited to stock on hand.
**For example, you can buy a hood strap kit and get a tow strap or bolt kit 1/2 off.*
Special Black Friday doorbuster sale deals are also listed in link below in addition to the BOGO deals.
BF doorbuster deals: https://www.x-h2o.com/threads/jetmaniac-black-friday-doorbuster-deals.206686/
JetManiac Ratcheting Hood Strap Kits
Ratcheting hood strap kit- replaces or extra security with stock hood latch
*includes complete SS mounting hardware(bolts, washers, and nylock nuts) for both ratchet and straps. Standard bomber strong thicker straps or lighter weight strap option.
Buy one hood strap kit for $42.95, get second one for $21.48
JetManiac Tow Strap Kits
Towing Carabiners Kit - 'Surf Tested'
These are super high quality marine grade stainless steel tow clips are manufactured by Suncor Stainless for us, and have been surf tested over many years by hundreds of freeriders.
They are stronger than most carabiners and don't have the sharp ends which will snag on ropes and webbing. They are also all stainless, unlike most carabiners which have steel pins which will rust. They are smaller and lighter than most alternatives and have much higher strength rating.
Buy one tow strap kit for $20.95, get second one for $10.48
JetManiac Handlepole Limiting Rope kit
Limiting rope kit includes:
Stainless tray loop mount and hardware, 2 Stainless carabiners, Stainless pole mount, and rope kit with elastic keeper and clip to pole base area.
Buy one for $41.95, get second one for $20.98
JetManiac Factory Pipe Headpipe SS Bling Bolts
Do your factory pipe headpipe bolts look like the ones on the left?
Replace your rusty headpipe bolts with JetManiac's Stainless headpipe bolt kit.
If you have ever tried to find this bolt size locally, you know they aren't available in the US. These were sourced by JetManiac in Asia to get this rare size.
Buy one Factory Pipe bling bolt set for $24., get second one for $12.
Also on BOGO
Flywheel cover bolt kits
Mikuni carb allen bolt kits
Mikuni carb internal bolts kit
Intake manifold bolt kits
Cylinder Head bolt kits
Exhaust manifold bolt kits
Most any other bolt kit we have
Bpipe special stainless 10mm headed manifold bolts
Bpipe special stainless 10mm headed manifold bolts 5.95 BF sale 4.95
(for the hard to reach and tighten top center 2 bolts)
Buy one JM Bpipe special bolt for 4.95, get second one for 2.48
JetManiac Bpipe and Big Bore Bpipe gasket sets
Bpipe gasket set (61x or 62t exhaust manifold gasket and headpipe gasket) 19.90
Buy one Bpipe gasket set for $19.90, get second set for 9.95
Big Bore Bpipe gasket set (manifold and headpipe gaskets) 21.90
Buy one BB Bpipe gasket set for $21.90, get second set for 10.95
Kawi 750/800 Bpipe gasket kit $19.90
Buy one Kawi Bpipe gasket set for 19.90, get second set for 9.95
JetManiac Freeride Gasket Kits
62t/61x SuperJet/Blaster dual 38 with Bpipe and a/m head custom freeride gasket kit
For Yamaha or Kawasaki
http://www.x-h2o.com/threads/...Gasket-Sets-45
Buy one gasket kit for $49.95, get second one for $24.98
61x/61x Single carb with Bpipe and a/m head custom freeride gasket kit
OEM crank seals set for Yamaha or Kawi
OEM crank seals set for Yamaha 650/701/760/1100/1200 $58.95 sale 45.95
Buy one Yami seals set for $45.95, get second set for $22.98
Kawi 650/750/800 OEM genuine crank seal set $65.32 Sale 47.
Buy one Kawi seals set for $47., get second set for 23.50
ADA Head O-ring kit for Yamaha or Kawi
Or:
Blowsion 701/760 Head O-ring kit
Riva 701/760 Head O-ring kit
DASA head Oring kit
PHP head Oring kit
XS head Oring kit
Buy one ADA Oring kit for $19.90, get second one for $9.95
Specify which head you have, Orings are all specific to brand and application.
Also BOGO loose dome Orings for XS, DASA, PHP, ADA, Blowsion, etc.
Also PHP, Boyesen, Rhaas intake manifold speed plate Orings
Wrist Pin bearings for Yamaha or Kawi
Buy one wrist pin bearing for $18.90, get second one for $9.45
for Yamaha 701/760/1100/1200nonPV
or Kawi small pin or big pin
MSD Boots and terminals kits
MSD boots and terminals (set of 2 of each)
Buy one MSD boots/terminals set for $14., get second kit for $7.
JetManiac Pump Rebuild Kits
NSK Yamaha Pump Build/Rebuild kit (2 bearings/2 seals)
Buy one pump rebuild kit for $40.95, get second one for $20.48
Koyo Jap Oem bearing brand Yamaha pump rebuild kit (2 bearings/2 seals) $89.90 sale 64.95
Buy one pump rebuild kit for $64.95, get second one for $32.48
Setback Koyo MAG Pump Build/Rebuild kit (2 Koyo bearings/2 seals) $149. sale 119.95
Buy one pump rebuild kit for $119.95, get second one for 59.98
JetManiac Midshaft Rebuild Kits
NSK Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/2 clips)
Buy one midshaft rebuild kit for $41.95, get second one for $20.98
Koyo Jap Oem brand Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips) $64.95
Buy one midshaft rebuild kit for $64.95, get second one for 32.48
More deals in the following posts below....
Also on BOGO
Or:
DASA head Oring kit
PHP head Oring kit
XS head Oring kit
