New JM Fuel Shop- Carbs, Carb Parts, Primers, Filters, Intake, Reeds
JetManiac
Stoked
Vendor Account
orlando
JetManiac's Fuel Parts Shop
Carbs, carb rebuild kits, jets and replacement parts, throttle wheels, fuel filters, check valves, primers, carb base gaskets, fuel line, popoff testers, flame arrestors and adapters, reeds and reed cages, intake manifolds, gas caps, internal fill.
Carb Rebuild Kits
Mikuni
Mikuni OEM genuine SBN carb rebuild kit $63. Sale 49.95
(Fits OEM Mikuni 38mm and 44mm, Aftermarket Mikuni 44, 46, 47, 48, 49, 50mm)
SBT carb kit for Mikuni SBN 38.
Mikuni genuine OEM sbn-I Yami 800/1200 carb rebuild kit $64. sale 52.89
Mikuni BN38/44 round body/older style carb rebuild kit 39.50
Keihin
Keihin
38/40mm & 42mm CDKII (Kawi) genuine OEM carb kit 76.45
Keihin genuine CDKII carb fuel pump rebuild kit 39.95
Keihin 28mm (Kawi) genuine OEM carb kit 50.95
Kawi J650 SX 86-91 & 650 X2 86-91
SBT carb kit for Keihin CDKII (kawi) 38.
Keihin intake manifold to Mikuni SBN carb billet adapter 39.89
Carb parts
Mikuni genuine OEM N&S (1.2, 1.5, 1.8, 2.0, 2.3, 2.5) $23.90 sale 21.95
Mikuni genuine OEM popoff springs 65g, 80g, 95g, and 115g
Mikuni genuine OEM sbn main/high jet 4.95
*sizes from 30 to 200
Mikuni genuine OEM sbn pilot/low jet 4.95
*sizes from 60 to 160
Mikuni genuine OEM throttle valve and shaft replacement kits 39.
* 38, 44 or 46mm, complete kit with shaft, throttle valve, screws, seals and bushings.
Mikuni SBN genuine throttle return spring 12.90
Soft throttle spring for Mikuni SBN carb (Japanese) 26.95
Mikuni SBN idle adjuster T handle with spring 9.95
ADA billet throttle wheels 24.95
(available in black, silver, blue, green, orange or red)
JetWorks T-handle dual 38 SJ long mixture screw-High speed 15.59/ea.
JetWorks T-handle dual 38 SJ long mixture screw-Low speed 15.59/ea.
(Replaces the hard to reach low and high speed adjustment screws in 2004-up Yamaha Super Jet carbs.)
NOTE: Choke must be removed to install T handle high Adjustment Screws.
Mikuni High speed T handle adjuster 8.95
(Fits most Mikuni SBN carbs)
Mikuni Low speed T handle adjuster 8.95
(Fits Mikuni 44, 46 SBN only a/m racing carbs, does not fit oem carbs)
Mikuni low speed T handle adjuster 15.95
(Fits most Mikuni OEM 44 single and duals only)
Mikuni low speed T handle adjuster 17.95
(Fits Mikuni OEM dual 38s 96-03SJ and 62t couch only)
JetManiac allen head stainless replacement bolt kit for Mikuni SBN carb $9.90
*Replace those crappy easily stripped carb screws with JetManiac's stainless steel allen head bolt kit for Mikuni carbs. JM kit includes:
4 SS allen bolts for diaphram cover
4 SS allen bolts for fuel pump with flat and lock washers
(or custom bolts for slave carb on dual 38 setup)
Mikuni genuine OEM Internal replacement carb screws kit of all 5 screws $6.95
Mikuni genuine OEM dual carb linkage kit 27.90
JetWorks dual carb linkage 39.95
Mikuni SBN genuine carb replacement fuel pump cover plate with pulse nipple 16.95
(fits all sizes of Mikuni SBN carbs 38, 44, 46, 48, 50mm)
Mikuni SBN genuine carb replacement fuel pump body
*with check valves and grommets installed.
JetManiac dual carb brace $35.95 (Black, silver, or red only)
*includes stainless hardware, for Yamaha twin setups with Boyesen, Dasa, PHP, other manifolds.
Carb throttle cable mount bracket (fuel pump side) 28.95
Carb throttle cable mount bracket (diaphragm side) 28.95
Fuel Filters and fittings
Fuel Filters
High-Capacity fuel filter with 80 Micron treated fiber element 5.95 ea.
4 pack special 4 for 5.49/ea.
6 pack special 6 for 4.95/ea.
Slimline fuel filter with 90 Micron white polyester element 7.95 ea.
2 pack special for 7.49/ea
4 pack special for 7.25/ea
6 pack special for 6.95/ea
OEM Yamaha fuel filter 32.99
OEM style a/m fuel filter 9.50
Fuel tank check valve 7.95
(2 for 14. or 3 for 19.90)
Yamaha OEM Fuel tank check valve $35.99 sale 30.90
Fuel line T or Y adapters 2.50/ea.
Fuel tank compression fitting 6.49
(Replace or add a fitting to your tank)
Fuel tank pickups 'clunks' 7.95
Brass 1/4" fuel line barbed straight connector 2.95
Fuel line return Y tapped with 60 main jet restrictor 14.90
Fuel line straight barbed tapped with 60 main jet restrictor 16.90
Fuel Line
Fuel line -translucent blue 1.59/ft.
Fuel line -translucent red 2.25/ft.
Fuel line -translucent neon green 2.25/ft.
Fuel line -translucent orange 2.25/ft.
OEM fuel line
*This is the best quality fuel line, made in Japan, lasts and stays flexible for many, many years. Grey or black.
* No air or fuel leaks with this fuel line.
Grey OEM fuel line -9ft roll $33.90
Black OEM fuel line -9ft roll $32.90
Black OEM fuel line -18ft roll $59.85
Black OEM fuel line -27ft roll $84.95
Larger diameter Black OEM fuel line -5.25ft roll $25.95
*for external fuel pump supply and pickup lines
Dual 38 carb to case pulse OEM precurved hose 11.99
Dual 38 rear to front carb OEM precurved hose 15.99
Waterline
3/8" water line -translucent blue 1.79/ft
Black or Blue silicone 3/8" waterline 2.59/ft
OEM Yamaha fuel selector switch only 34.90
(on/off/reserve switch, clean used, JM certified or new a/m)
OEM Yamaha fuel selector switch assembly 49.90
(on/off/reserve switch, clean used, JM certified or new a/m, with NEW OEM knob, hull nut, and SS hardware)
*specify SJ or Blaster, new oem 59.90
SuperJet fuel selector switch knob -OEM 10.99
Blaster red knob for fuel selector switch -OEM 15.99
Stainless allen bolt/washer for fuel selector switch knob -a/m 1.50
Replacement OEM nut to hull for fuel selector switch 7.99
Choke
Choke knob -OEM Yamaha SJ, Blaster, FX1 18.99
Bolt for choke knob -OEM 3.99
Replacement choke cable
Primer kits, primer line, primer parts
Primer kits
Primer kits are complete with choice of bulb or plunger primer, primer line, fittings for fuel line and for primer line, and with brass primer fittings and plugs for carbs.
Single Mikuni plunger carb primer kit 29.95
Dual Mikuni plunger carb primer kit 35.95
Triple Mikuni plunger carb primer kit 39.95
Single Mikuni bulb carb primer kit 33.95
Dual Mikuni bulb carb primer kit 39.95
Triple Mikuni bulb carb primer kit 44.95
Keihin carb primer kits also in stock.
Primer kits with OEM primer line option in stock.
Primer Replacement Parts and Primer Line
Replacement Plunger Primer 19.95
Replacement Bulb Primer 24.95
Watt hole bulb primer or rotary bilge recessed mount 34.95
OEM black primer line 5ft roll $13.95
10ft roll $24.90
Primer fuel line -blue translucent .89/ft
Fuel line to primer line T primer fitting -nylon 2.75
Fuel line to primer line T primer fitting -brass 5.95
Primer line to primer line T primer fitting -nylon 2.50
Primer line to primer line T primer fitting -brass 6.39
Brass primer nipples for Mikuni SBN carb 3.29
Brass plugs for Mikuni carbs 3.19
(these are pressed into holes left after removal of choke shaft)
Mini primer nipples for some a/m carbs 4.25
Brass plugs and primer nipples for Keihin carbs 3.95/ea.
CHOKE Knob -OEM Yamaha 15.99
Mikuni Carb Popoff Tester
This a critical tool for use when rebuilding and tuning carbs.
Use to verify actual popoffs on your carbs (springs are often off) as well as testing for leaking needle and seats and leaking carbs/fuel pumps after carb rebuilds.
Includes instructions for popoff testing
Mikuni genuine OEM carb popoff tester 0-60psi $63.90 sale $59.89
External fuel pumps, blockoffs, larger fuel line
Mikuni genuine OEM external fuel pump 64.95
Mikuni genuine OEM external fuel pump rebuild kit 21.95
Mikuni SBN fuel pump blockoff plate with JM hardware 18.95
Oem style fuel filter for the larger fuel supply line 16.90
JetManiac
Stoked
Vendor Account
orlando
Flame Arrestor/Air Filters
index.php
Tau Ceti Tornado and Prok flame arrestor/air filters
Prok Flame Arrestor $53.90 sale 49.95
Prok Prefilters 11.90/ea.
(aka 'raincoats' 'Outerwears')
*Note: Tau Ceti filters were discontinued
Tau Ceti/HP filter outerwears/raincoats 22.85
RIVA power filter 49.95
Yamaha OEM flame arrestor/air filters
OEM dual 38 flame arrestor assembly 49.80
(clean used, f/a base plate, 2 screens, plastic top with rubber 90 degree, hardware to top and to carbs)
OEM dual 44 flame arrestor assembly 49.80
OEM single 44/46 flame arrestor assembly 45.
(oem clean used, base plate, screen, plastic top, hardware to top and to carbs)
JM stainless allen bling bolt kit for OEM sgl f/a 7.90
JM stainless allen bling bolt kit for OEM dual f/a 9.89
Flame Arrestor to Carb adapters
index.php
ADA billet 44mm carb to flame arrestor adapter 22.99
ADA billet 46mm carb to flame arrestor adapter 22.99
index.php
ADA
SuperJet 38mm carb to flame arrestor adapter 22.99
ADA Kawi SXR carb to flame arrestor adapter 22.99
Billet aluminum air filter adapter for the Mikuni 40mm carb. Fits the stock carb on all Kawasaki SXR800's.
ADA Kawi 1100 carb to flame arrestor adapter 24.99
Flame arrestor adapter for the stock Kawasaki 900('98 and earlier) and 1100ZXi('97 and earlier) carbs. These do NOT fit the newer CV style carbs.
Keihin adapters available also.
Reeds, Intake Manifolds and Carbs
Carbon Tech carbon fiber reed sets
Yamaha 701 61x sgl carb cases -low tension for freestyle $105. sale 95.
Yamaha 701 62t dual carb cases -low tension for freestyle $105. sale 95.
Kawasaki 750/800 carbon reeds 115.
Boyesen Power Reeds -Dual-flex epoxy fiber
Boyesen Power Reeds -Dual-flex epoxy fiber Yamaha 701 61x sgl carb 79.
Boyesen Power Reeds -Dual-flex epoxy fiber Yamaha 701/760 62t dual carb 79.
Kawi 750/800 Boyesen Power Reeds -Dual-flex epoxy fiber 89.
Kawi 650 Boyesen Power Reeds -Dual-flex epoxy fiber 79.
Kawi 550SX Boyesen Power Reeds -Dual-flex epoxy fiber 79.
V-Force 2 Reed Cages and Reeds
The V-Force 2 Reed Valve uses a double row cage design for additional flow at all RPMs. Reed stops and rubber over-molded cages extend reed life and eliminate petal distortion. Specially developed carbon fiber reeds offer the ultimate in response and durability. The V-Force increased flow results in significant horsepower gains with freestyle pulling torque and broader peak horsepower...
Open up and Say 'AHHH!' Let your motor breathe with two rows of reeds instead of one.
VForce 2 mounted on stock/oem intake manifold for dual 38's. Also fit with stock/oem dual 44 manifolds and most a/m manifolds as well.
We have used VF2's in stock 701/bpipe setups and also in ported 701 and Big Bore ported 781's with excellent results for freestyle.
VForce2 Reeds/Cages for Yamaha 62t/64x motors 259. -check with us for any current sale pricing
(2 Cages with carbon reeds, gasket, instructions)
VForce3 Reeds/Cages for Yamaha 62t/64x motors $259. -check for any current sale pricing
(2 Cages with carbon reeds, 4 reed gaskets, instructions)
VF3 reed gasket 5.25 (total of 2 per cage needed)
Replacement Reed Sets
VForce 3
replacement reeds 59.95/cage set
VForce 2 replacement reeds 59.95/cage set
VForce 1 replacement reeds 59.95/cage set
Boyesen replacement RAD valve reed sets 69.95/cage set
Intake Manifolds
index.php
PowerHouse Products (PHP) billet intake manifold
This is a state of the art billet intake manifold for Yamaha 62t or 64x cases. This intake was designed specifically for freestyle and features shorter and better designed intake track for more freestyle low end performance. Removable O-ringed billet carb speed plate makes removing and reinstalling carbs easier while preserving carb linkage alignment.
PowerHouse Products (PHP) billet intake mani $449.95 sale 418.95
(Includes manifold, speed plate with orings, throttle cable bracket, and all SS hardware)
http://www.x-h2o.com/index.php?threads/php-intake-manifold.162601/
OEM intake manifolds
61x single 44 OEM intake manifold clean, used $18.
62t dual 38 OEM intake manifold clean, used $30.
62t/64x dual 44 OEM intake manifold clean, used $39.90
OEM manifold throttle cable mount brackets
OEM reed cages
61x OEM reed cage with reeds clean, used 19.90
62t OEM reed cage with reeds clean, used 21.95
JM Allen stainless reed cage to manifold bolt kit (4 bolts/washers) 5.
Carburetors
- Mikuni new 44mm SBN racing carb -PM for current pricing
- Mikuni new 46mm SBN racing carb -PM for current pricing
ADA Yamaha or Kawi billet gas caps 64.95
OEM Yamaha clean, used gas cap assembly 29.80
(hull side mount with gasket, chain, and gas cap with gasket, black or white)
Cold Fusion internal fuel fill system 179.90
Blowsion internal fuel fill system $179.
RRP 5 gallon front fuel tank kit $389.
- Replaces an oem sized SuperJet tank. Fits all SJ's '90-'20, and all a/m hulls which use SJ tank. 19.5 L/5.15 gal capacity.
- Billet 4 port internal fill with cap allows for all connections with no need to put fittings in tank.
- Natural tank allows for fuel level inspection.
- Comes complete with all necessary hardware and fittings.
(Compare pricing with a new oem tank, then add price of internal fuel fill and a blockoff cap for inlet.)
RRP rear fuel tank cap Oring 2.95
RRP rear fuel tank gasket 13.89
Lightweight composite tank holder keeps your stock SJ tank from sliding around during riding and is great for surf and big freestyle tricks.
Made by Tigercraft.
SJ OEM or CF fuel tank cradle $98.95
modularjunk
day dreaming
Long Island
shoot jetmaniac a pm for fastest response if you are "ttt" for the answer to your prev question. hes super fast at getting back to you and may have missed this question in the thread
