- New Zealand
Hi there, you might have noticed I'm new here, also new to Jetskis so bare with me.
I recently purchased a JS300, At a guess its a mid eighties model looking at pictures, Pink, Green and White. "Hawaiian Style" (according to the decals)
Its pretty rough and gutless, but the bloke who sold it to me, told the story that he was given it, in pieces, with some form of engine failure. He says he had the Jet unit rebuilt, and 'rebuilt' the motor, then it never saw any water time untill I brought it.
Apparently the oil system has been disconnected, I'm having trouble making sense of the plethora of fuel/oil lines running everywhere though. I'm currently running 50:1 premix, How does this sound?
My problem is this, I can't seem to tune it very well, just about no position on the jets seem to make it much better. It doesn't run bad wide open, but anything below say, 80% throttle, it bogs, surges and generally runs hairily.
Very difficult to get it to idle consistantly, and if you pull the plug after stalling it, it won't be very black, but still damp with fuel.
Will only restart if you hold the throttle wide open.
I know this sounds like its running far too rich, but in my last effort to tune it, I had the low speed jet screwed basically all the way in and it still runs.
Up to this point I've generally just been backing my truck down to the water, tying it to the truck, and fiddling away with it running in an attempt to find its sweet spot..
So, sorry for the long and possibly confusing read, but what do you lot suggest I should focus my attention on next? Air leaks? Carb?
Thank you
John
Thank you
John
