Ok I've searched all over so please don't tell me to search. I have new cdi, new spark plug eveything. Is it possible for the magneto to go out and would that cause no spark to start? Thanks, Dustin!
Sounds like a stator thing.
I only know Yamaha, but resistance checks are the way to know for sure. If you can find a service manual for your ski, then you should be able to find those resistance specs.
Otherwise, you're "parts swapping".
I've had folks tell me I had a coil issue....a stator issue....a cdi issue.....
Ya just don't know til ya check.
Check the Start stop switch! Open it up and disconnect the stop portion and check spark again! Let me know if you need any parts I have everything, e-box, stator, coil.
