Ok so just swapped twin 38's for a single 48 Novi and now im having a small problem.
When i come off the throttle completely and hit it hard it hesitates (say 1-2 seconds) before it hits.
If i just keep it blipping and hit there's no problem.
I'm guesing this is an over fueling isuue?
I've done the usual checks without going to mad....I'm 99.9% this is fuel not electrical.
Tank is holding pressure and non return is ok
changed plugs
checked carb over, cleaned and checked jets....all looks ok.
checked down the carb when its running to see if needle is letting fuel through.
I did read a Mikuni trouble shooting guide and it mentioned fitting an extra non return valve in the carb but this was for when you come off WOT to nothing and then having nothing...
Any help from you carb gods would be really greatful as it's not a strong point for me.
changed plugs
