Just got the backflip!
Friggin like 3 years of chasing this dream. First year plagued with epic ignition issues, then carb issues, then setup issues....ect $$, $$$ spent on this stupid thing I finally nailed it!
Ski was running good this year and I knew I was close so I decided to send blowsion an email and ask what parts I needed. Shane sent a list of parts in order of importance. 148 pump 8/15 prop showed up, then a tnt pipe. Pump made a big difference and pipe meh... idk maybe it's not tuned well enough.
Then my thigh karate chopped my handle bar and it ripped the turn plate right out of the X metal pole. So a few days later a new blowsion work of art pole showed up. $$$$ later ugh....
Many many flops and coming really close I finally landed one. It was quite awesome. I now know how to do it but nailing the wake every time is the hard part.
Sent from my SAMSUNG-SM-G890A using Tapatalk
INDebtSJ
Having a VISION!
Ga
What pump were you running?
I am either getting a 148 or a pipe. Now I am thinking pump. Seems the pipe is hit and miss or a ton more tuning.
Roseand
The Weaponizer
Wisconsin
Nice work! You're definitely going way too fast. Even with a 701 I go pretty slow and do a pre hop. To take full advantage of a laydown pipe you need to spend the time dialing in temperature and pump load. I noticed a world of a difference over a b pipe on my 701. I run a tnt v3.
The pipe I don't think is getting hot enough. I put the smallest jet I had 87.5? I think. and you can still grab it. It also gave it more power no question but $1600 more um I don't know yet.
I went from a 11/17 144 to this pump and it definitely felt more thrust.
Blowsion bb850 62t cylinder. 46 carbs stock electronics
I have a few more flips on vid I will see about going slower. The wake is so hard to master
INDebtSJ
Having a VISION!
Ga
Which 148? Solas?
N3vrSat1sfied
Military Member
Fort Worth, TX
PFP with water injection? if so you should be running around a 45 main. Pipe needs to be 170-180, waterbox stinger should be like a 105 (i think) looking for 80 degrees on box
Just for my future reference, what's the water temp.
I going to assume you have a lot of timing and don't pull much of it. If you were running an enhancer that would be a different story. Setup is always key and each setup will vary in jet size.
