- San Diego
So my current problem is that after about 15 minutes of run time(hard run time) once everything is hot, I have a bad misfire like it’s only running on one cylinder. Someone in a previous thread that I believe had the same problem described it as the sound of slow machine gun fire. There was no resolution in that thread. Only the one post stating the problem actually. This is a mystery to me since this is a lost spark system and it can’t possibly be firing only one cylinder-I don’t think. I have tried swapping multiple things with the same results including spark plugs(which I also tried .020 gap with no change), cut wires back, stator, even swapped in a whole different e box with CDI and coil. The e box has not been tested but performed as it should for 15 minutes until the same problem occurred. I think I have swapped everything and the problem persists. I have been to the bay to test and failed five or six times now so it’s getting old. The last time I did not have my test E box secured well as the wires are short and it pulled a sp boot off the plug. I limped back on one cylinder running just like it does when it gets hot, cut the wire back 1/4” and it ran for a few minutes till it got hot and did the same thing. Once it is hot and misfiring it’s pretty much game over for that day. It needs to cool for a long time before it’ll be back to ripping…for 15 minutes. A long time ago I had a similar problem due to a fuel filter that was getting too restrictive after about half a tank but I have been through my fuel system, have no filter and even got a new sbn46 chasing a recent fuel problem.( My fuel pick up tube was leaking under the fuel cap but only at high rpm AND the seals on the butterfly shaft on my carb were worn.instant runaway.) It definitely feels like ignition to me now. Right now I am suspecting a coil so I will buy a brand new OEM SXR coil. It seems like it could possibly be broken sp wires but I have tested with the second ebox and coil so ?? Sorry for the long read, this is frying my brain!
Thanks for any help, there’s got to be something I’m missing
