Used ++ KAWASAKI PARTS ++ 750sx & 650sx & X2 & 550 & SXR800 & 440 & MORE
dirkdiggler
Vendor Account
WI
KAWASAKI - MOTOR:
KAWASAKI 750 MOTOR = $539
Kawasaki 650 Motor = $299
KAWASAKI - High Compression HEADS:
750sx Wescoast head = $140
650sx Mariner head = $110
650sx / x2 PJS Head = $130
650sx / X2 Westcoast head = $130
550 PJS high compression head = $99
KAWASAKI - EXHAUST:
SXR-800 R&D DRY PIPE = $450
Kawasaki 750sx factory B-pipe EXHAUST SYSTEM = $490
Kawasaki 750sx Westcoast exhaust is $299
650sx / x2 westcoast exhaust = $185
650sx / x2 Mariner Exhaust = $175
650sx / x2 Stock exhaust = $30
650sx / X2 WC exhaust manifold = $99
550 / 440 Coffman Exhaust = $189
KAWASAKI - WATERBOX:
750sx Aluminum Waterbox = $95
650sx / X2 Westcoast Water Box = $90
650sx / X2 PJS Water Box = $90
650sx / X2 Stock waterbox = $35
Kawasaki 550sx aftermarket water box = $80
KAWASAKI – Electrical :
550 / 440 Total Loss = $199
650sx / X2 Aftermarket Flywheel = $299
650sx / X2 Relay = $29
650sx / x2 Complete electrical Box with CDI = $150
650sx / X2 CDI / Coil with wires = $99
650sx / X2 STATOR - $89
X2/ 650sx / 750sx OEM STARTER = $49
650sx / 750sx Aftermarket BRAND NEW Starter = $79
750sx 650sx X2 STARTER BENDIX = $29
550 / 440 Complete Electrical Box = $110
550 / 440 Stator = $55
550 / 440 Starter = $55
KAWASAKI – CARBURETOR:
900 Triple Carburetors = $99
Mikuni SBN 44 Carb - $95………best upgrade for 550 and 650sx and 750sx
Mikuni 46mm carb = $175
Mikuni SBN 38 Carburetor - $75…….also a good upgrade for 550, 650sx
kehin 38mm Carb - $75 ……..bolts onto 440, 550 and 650sx….Great upgrade
DUAL 750 Kehin Carbs - $125
KAWASAKI - INTAKE MANIFOLD:
750sx / sxr800 R&D Single Mikuni Carb intake manifold = $145
650sx / X2 Mikuni SBN 44 INTAKE MANIFOLD = $110
550/440 dual carb intake manifold = $40
550/440 aftermarket single 44mm intake manifold = $75…. Great upgrade
650sx / X2 R&D Dual mikuni SBN44 carb intake manifold - $79
550sx Intake Manifold for the Kehin single 42mm CDK2 Carb = $60
1991+ 550sx Dual Mikuni carb manifold = $45
1991 + 550sx single 44mm manifold = $145
KAWASAKI - REEDS:
650sx / X2 boysesn reeds with cages - $55
650sx / X2 aftermarket cages with aftermarket reeds = $75
750sx aftermarket Boysesn Reeds with Cages = $ 55
KAWASAKI - RIDE-PLATE & INTAKE GRATE:
650sx / X2 R&D Scoop intake grate = $95
650sx / X2 PJS Scoop intake grate = $95
X2 TDR racing rideplate - $79
650sx Ocean Pro Ride plate - $69
750sx Jet Dynamic scoop grate = $110
750sx R&D rideplate = $79
750sx Scoop Intake grate = $80
Kawasaki – Impeller & Pump:
750sx / 750sxi Pump with impeller = $149
550 / 440 impeller - $75
650sx / x2 Skat-trak impeller many different ones = $89
750sx aftermarket impeller = $99
Kawasaki – BODY:
BILLET aluminum FINGER Throttle = $345
650sx Hood seal - $45
650sx front plastic nose = $70
X2 front Plastic gas cap Cover = $70
650sx Pole Pad = $59
Kawasaki – POLE:
BILLET aluminum FINGER Throttle = $39
750sx pole - $89
Sxr800 pole = $89
750sx / SXr800 aluminum Pole = $275
650sx steering cable = $75
650sx aftermarket Pole Spring = $65
KAWASAKI - MOTOR MOUNTS:
650sx ,X2, 750sx 4 Motor mounts = $40
I am interested in the mariner exhaust
do you any pics and will it fit in a js550 hull
is it the long one that gives you lots of power out of the hole I am open to suggestions I have:
premium sbt 650
super bn46 hCW53-0660HOT
solas imp sized for 550 full mod
550 hull
west coast intake
stock exhaust mani
ocean pro flame and filter
interested in some of the 750 parts.
Factory pipe.
R&D Ride Plate
Scoop Intake
Impeller
Do you know what ride plate it is? Speed, PRO?
Any idea what the impeller pitch is?
