Kawasaki SXR 1500 Billet Fuel Pickups
If you’re interested in running an external fuel pump setup on your 2017-2024 Kawasaki SXR 1500 or aftermarket hull using the Kawasaki 1500cc engine this is the missing component not available as an off-shelf item needed for the DIYer to complete the package.
Also a necessary component of swapping a different engine into a 2017-present SXR hull when the OEM fuel pump is removed. Great for putting that empty SXR hull to good use.
6061 T6 aluminum, clear anodized for corrosion protection, and tapped for 1/8NPT fittings.
$55 + s/h
$55 + s/h
I need 2 of these how do I put purchase?
