so, I’ve never really thought about this but when your doing a race hull with the Kawi 1500 engine, what harness and electronics are you guys using? I get if your pulling the engine out of a sxr1500 it’s pretty cut and dry but what about the stx models? Bc they have a gauge and probably longer wires or even maybe shorter wires in some cases. I know when I worked in the dealership when the Kawi gauges would take a crap from water intrusion they wouldn’t let the ski run at full potential if not at all. You couldn’t just unplug it and go on your way neither. Do you repin? Do you buy a sxr harness? Do you have to buy a sxr ecu?
stx will swap over. manifold and throttle body faces same direction as sxr so cant see why it wouldnt fit.
stx ecu is fine. you will either have to chop up the harness or zip tie extra wiring in loops.
the one thing you'll need is to order a fuel tank, run new fuel lines, and oil tank modification.
a motec is about $5000, really have zero clue as to how that is cheaper than a stock ecu.
also a lot of the flashed ECU's run like crap. yes they run, but have weird tendencies from the flash "work a rounds" and not being actually tuned to the engine like a motec or emtron can be with a lambda and AFR.
motec can be tuned by your tuner over the internet as long as you have 4G or wifi and a laptop hooked up to your ecu. so they can check logs and ask you what its doing and tune it on the beach without ever being there after setting up a good base map, and keep it on open or closed loop tuning.
