Kawi 750/800 Blocked Intake Passage ???
ohell
learn to swim
anyone want to type smack about blocking the intake passage on Kawi stock mani ?? like most people, interested in bottom end over top. I'm guessing from what little i can find around the forums - looks like open is better for bottom end.
been there, done that...... any comments are appreciated. :hail:
Scorn800
Ride for life
North NJ
I've personally never used it but this it what I know.
I know Group K swears by it. Ive ridden a group K sleeper sxr with their carbs & manifold. boat pull nice midrange. Nice boat to practice bouys on. I really wouldn't say it had better low end than a stock boat. We lined up. I have a bone stock 06 sxr & the sleeper. I hole shotted him, he caught me then pull maybe 1/2 boat length and stayed there.
I know you must jet lower.
I run Z force carb mod & ported manifold/vforce on a full limited. Boat pulls very hard. I'm happy with them. I see know reason to fill the crossover.
Please let me hear all your info
ohell
learn to swim
yea, i know the reason given is carb inlet signal, personally i think it is a conservitave move because you have to lose some carb signal when the stock carbs are true bored. IMO - contrary to Harry Klemm, this would be more so then crankcase inlet signal loss due to porting.... after all the carb venturi has been opened a lot with true bore.
the kawi engineers used it "to improve low end response". not sure what the intent of that statement is... i'd guess they designed it to improve the initial lean spot that can occur from start up or long idle to wot hit.
can't think of any other 2 stroke pwc carb mani that shares or kinda equalizes dual carb circuit.
just trying to wrap it up in my head as to what affect it might have on bottom end - open/closed. since not many of us use radar gun to compile acceleration runs, basically looking for subjective evaluation from someone that ran both set ups. if no response, i'll try to drag post out again after i try. i'd guess stock air box and open passage is better, probably blocked with open FA's.
when looking for bottom.... to close or not to close ....???
thanks for reply Scorn...
when i finish other projects, i think i'll use z force for some rec porting on sxr, heard all kinds of good stuff about limited set ups out of his shop. I'm guessing from your reply that tim doesn't block passage after porting ???
Crab
thanks darin...noswad!
Seattle
Everyone I talk to says block it off if you are not running a stock setup. My 752 is ported, B-pipe, mod airbox etc., I have heard to jet down when blocking it off, and jet up when porting and pipe. So I will probably stay with stock jets and see what happens.
