JetManiac stocks lots of parts for your Kawasaki.
OEM Kawasaki and Kawi aftermarket parts, repair parts, upgrade parts are all available from JetManiac.
Kawasaki 650/750/800 Motor parts
Kawi 650/750/800 OEM genuine crank seal set 65.32 Sale 39.90
ProX piston kits for Kawasaki 149.90 sale 104.50
(Piston, rings, wrist pin, circlips)
WSM piston kits for Kawasaki 650, 750
Wrist pin bearings for Kawi 2x 17.89
Rebuilt Kawasaki 750/800 OEM Big Pin crankshaft 349. with core return
(All new bearings and rods, trued and welded, 1 year no fault warranty, includes 2x wrist pin bearings)
Boyesen Power Reeds -Dual-flex epoxy fiber Kawi 750/800 79.
VForce 3 for Kawi 750/800 $260. sale 248.
Gaskets
Kawi 650/750/800/900/1100 Gaskets -all in stock individually or in custom kit to your setup.
ADA Racing Oring kit for Kawi 750/800 cylinder head $23.95
Crankcase drain blockoff for Kawi 650/750 14.95
Oil pump blockoff for Kawi 650/750 12.95
Flycover Oring for Kawi 650-1100 8.
Kawi 750/800 Bpipe gaskets
Bpipe stainless headpipe bolt kit longer length for KAWI $19.95
* 3 Stainless Allen head headpipe bolts, SS flat and lock washers)
Replacement O-Ring kit for Factory Pipe dry pipes fits Kawasaki 750/800/SXR Dry Pipes
FP Dry Pipe O-ring Kit (3 large Orings) 12.95
Factory Pipe wet pipe or dry pipe silicone headpipe couplers 19.95
Kommander / JSU SXR Head Replacement O-Ring Kit 24.95
Jetnetics Timing advance kit for Kawi 750/800 39.95
SXR 800 / SXi 750 timing kit produces a substantial performance gain with the OEM ignition system. By relocating the pickup trigger on the ignition cover a full six degrees of ignition timing is available. Easy installation.
Thick flycover gasket for use with timing advance kit $11.95
Kawasaki 900/1100 Motor parts
ProX piston kits for Kawi 900/1100 $129.90 sale 104.50
Wrist pin bearings for Kawi 2x 17.90
Rebuilt Kawasaki 1100 OEM crankshaft 385.
(All new bearings and rods, trued and welded, 1 year warranty)
Kawi 900/1100 OEM genuine crank seal set $91.77 Sale 69.90
Kawi 1100 oem style head gasket 42. sale 29.90
Kawi 1100 cylinder base gasket 13. sale 9.
Kawi 1100 exhaust mani gaskets 3x 7. sale 3x 5.
Kawi 1100 headpipe gasket 12. sale 9.
Kawi 1100 muffler gasket 13. sale 9.
Oil pump blockoff for Kawi 900/1100 12.95
Kawasaki 440/550/650 Motor parts
Kawasaki electrical parts
Kawi 750/800 OEM genuine ignition coil 103.90
Kawi 550/750/800/900/1100 OEM genuine starter relay $101.60 sale 86.95
Kawi 550/750/800/900/1100 a/m starter relay 39.
Kawi 650SX/X2 a/m starter relay 39.
(4 wire model)
Kawi ebox ADA replacement billet fitting
Kawi ebox ADA replacement billet cap
Kawi replacement 4 pin electrical connector
Starters
JM OEM Kawasaki starter 99.
(clean freshwater starter, cleaned, inspected, lubed and tested, 90 day exchange warranty)
New SBT Hi-Torque Kawasaki Starter 129.90
(1 year warranty)
*Starters fit Kawasaki 650/750/800/900/1100 motors
Starter parts:
Replacement Starter nose O-ring a/m 2.50
Starter OEM rubber seals 7./ea
(seal between center section and front and rear sections- 2 needed)
Bendix / Starter drive
Aftermarket bendix just aren't up to OEM quality but are also quite expensive new. Failures of OEM bendix are usually due to water intrusion or the inner metal weight plate ears breaking off allowing the weights to move around, and then break their locating spring allowing bendix to stick open.
JetManiac OEM bendix are inspected for inner weight plate having all 3 ears intact and replaced if needed, teeth and end surface condition, etc., they are cycled repeatedly to check action, reverse drag checked and lubed with special Corrosion X HD lubricant/protectant.
(bgrade cosmetic available for less)
**If you have had bendix issues or are building a new motor, also make sure to check the soft bushings in the crankcase and inside the flywheel cover. Bendix should go in relatively tight and not rock much from side to side. The case side is especially prone to wear.
JM OEM bendix for Kawi 650/750/800/900/1100 $87.80
*Tested/inspected/lubricated and come with a 4 month exchange warranty
(water intrusion is not covered.)
New OEM Kawasaki bendix $387. sale 298.
Lanyards
Kawi a/m floating lanyard 13.50
Under construction....
Gaskets
(4 wire model)
Starters
(1 year warranty)
Starter parts:
Lanyards
