Kawi Yami convertion
I'm trying to figure out if you can run a kawi motor with a Yamaha pump in a Yamaha based ski. I know you most likely need a mid shaft conversion kit but I'm not sure, not familiar with kawi. Anyone have advice?
Yes you can. You will need a conversion plate so that you can bolt your motor into the Yamaha and you will need a matching coupler. I got my coupler setup at ColdFusion but a ADA makes them as well.
