- Cape Canaveral, Fl
Wires keep burning up on my superjet. The plastic coating does not melt, just the wire inside turns black and loses conductivity. I have had to re-wire my bilge pump 2 times in 4 months because it has stopped working (maby bad bilge switch?). The wires are not corroded, and I only get about 8 rides out of the ski before I have to re-wire.The bilge pump still works after i re-wire it. Now after taking my start/stop switch off, I noticed the brown wire is also starting to burn inside the plastic (only the brown wire). The brown wire is progressively burning from the connection off the e-box towards the start/stop switch. It was burned about 1/2 the way to the start/stop switch. Does anybody know what would cause the wires to burn like this?
