squiggy_bum
Blasters, Broads, and Beers
- Fountain Valley
What’s up fellas, I am looking for some input on going up to bigger carbs. I’ve been doing a lot of reading but haven’t quite found my answer. I have 94 WB1 with a 62t/62t raider motor and the following upgrades:
Stock 38s with hot products filters and stock reeds (jetted with the coffmans recommendations)
Coffmans pipe
Solas 13/17 prop
Fresh bore to 81.5mm
Ported top end (not case matched)
Decked cylinder with stock head (~180 compression)
MSD enhancer
My main question is if it would be worth it to ditch the 38s and go to something bigger? If I did go to bigger carbs what would you recommend?
Coffmans pipe
Solas 13/17 prop
MSD enhancer
