Last ski I built I removed the flapper from the pump dump and made an alum plate to seal it, installed a short piece of PVC to make it a rear exit and used a versiplug max. Worked well.
As for the new predator with the rear dump I have not looked close enough at it to see if it's a round tube you could retrofit a versi into.
See if I can get a look at one this weekend and report back
