Krash Predator 830 sxr engine
hello all here is my build of my krash predator 830 cc kawasaki sxr engine...
i'm in disbelieve and am flabbergasted about the result this thing rips your arms out...and is such a fun and easy ride! if u want specs or want info just ask!
x2mafia
Maximum effort
WA
What did you have to do to fit the kiwi Powerplant in there? Just recap the engine plates on the hull? How did you like those kavinci motor mounts
I had to make a smaller tread in the kavinci couplers yamaha crank is bigger...then the beautiful kavinci motor mounts...they don't fit the sxr engine the engine is then 1 cm to high but I'm gonna make them fit with a new engine bedplate but later...becaus the mounts have to be used ;) with the sxr mounts everything is nice lined up and only bore an tap new holes in the engine hull plates
Verstuurd vanaf mijn SM-G920F met Tapatalk
Thanks! I had a sxr that i had build.so thought why spend more money lets see what i dos in there and love the result !
