was supposedly sleved to oem size ran a hone through it to clean up wish i would of checked cylinder now just trusted the guy i bought them from had new wsm sleves put in it
So nobody actually verified piston to wall clearance?
Imo, that's your problem right there.
but im thinking i may need to order wsm pistons for there sleves i put oem pistons and rings in it
No, you need to verify that the clearances are proper. There is absolutely no problem running OEM pistons in aftermarket sleeves as long as the proper clearance is there.
There is no one "OEM Size" that the WSM pistons will fit. You buy new pistons, give them and the cylinder to a machine shop and they will bore the cylinder to the right clearance.
Every piston is minutely different. My bet is that the bores are too big for the pistons. Nobody verified what the size was and then you ran a hone through it making it even bigger.
Those clearances are critical. If it's too big by even just five thousandths, your compression is going to be significantly lower.
