bad93blaster
X-H2
where can i get the bolts for a lamey cylinder or whats the length and head do i need ?(cyl to case)
bad93blaster said:where can i get the bolts for a lamey cylinder or whats the length and head do i need ?(cyl to case)
bad93blaster said:yes they are the same height. im guessing mine is the newer casting because it marked dasa instead of r&d or riva
WB800BLASTER said:adam,
i think i have set you can have. if i do i will bring them up next time i'm there.
once you get the pistons in it match the domes to that size and compression. if you buy a new head get the matching hardware. for what you are doing go with a rec type porting.
Jason,
its a non pv, stock stroke, 84 mm. for domed pistons.
pat
