- St.Louis Missouri
Just picked this gem up an hour ago..cant wait to ride it! Small list of mods include:
Riva built engine with porting, lightened flywheel, modded ignition, Red Pipe, Girdled head with 180 PSI compression, Dual Buckshot modded carbs(believe to be 44's?), full UMI steering, Tiny Tach, Jet Trim seat, duckbill drains, Rule 500 Bilge with waterproof handlebar mounted switch, billet umi throttle, aftermarket gas hood struts, scoop grate and ride plate...I may be missing a few things.
Definitely needs the engine bay cleaned up a bit..ski has been sitting for quite some time. Guy built it back in the early to mid 90's for racing..raced less than 10 times and it sat since. Supposedly he spent $3350 on just RIVA parts and work. He recently went back through it and cleaned everything..ski fires right up!
Here are some pictures!
What waterbox is this???
