- Ontario, Canada
I have been working on this Blaster doing multiple little things, improvements here and there. I rebuilt these carbs last year and they may have 10 rides though new kits. The carbs are Novi Max Flow 48's and have the little socket cap screws on the diaphragm side instead of the Phillips screws. We were out for a run last weekend when the Blaster started encountering some running issues. After going over everything and making a lot of corrective issues, fuel lines started to get loose, B-pipe coupler finally popped, etc. Little things, I noticed tonight after getting the pipe back together that the carbs are both leaking fuel through the diaphragm vent holes.
They were rebuilt using SBT kits, the diaphragms look like new as they should since they hardly have been used. But why the leaking through the atmosphere side of the diaphragms? What causes this on clean, new kits? I have seen it happen on kits that have seen hundreds of hours on them, they tend to wear a little hole out, but never seen it happen on new kits before. I decommissioned the ski until this gets cleared up, I don't want to see a fire happen. I tried changing the screws with the original ones from a pair of old 38's thinking that the socket head cap screws were not covering enough of the cover plate to seal, but that didn't make any difference. Would the cover plates suddenly warp and lose seal? Should they be changed too? Any thoughts on what to look for or change would be appreciated, thankya muchly.
