My background: Experineced engine builder and mechnaic. Experience with any thing from a chain saw to turbo v8's.
Issue: Super Jet sometime stalls during a long run at full throttle on flat water.
Ski: 2013 SJ - Purchased new in 2013, Ride 4-8 hours per week, Use non-ethanol fuel with Yamalube 50:1.
Mods:
-Blowsion S/S Intake Grate
-Impros Hooker impeller (10/16)
-Solas Yamaha 144mm 12 vane pump
-Dual cooling
-Scupper
-Stock rideplate for now(D-cut)
-Blowsion Steering, 0° bars
-TTO tach
-Wamiltons Bpipe - Mod Chamber
-Blowsion Flow control to stinger
-Blowsion Girdled Head, B8ES plugs
-35cc chambers
-V Force 2 reeds
-Blowsion F/A's with outerwears
-MSD Enhancer - Set to max RPM
Carb settings: Carbs cleaned and all new gaskets installed when carbs were jetted. Fuel system is stock including the selector valve and the fuel filter.
Main 135
Low 75
Low speed - 7/8
High speed- 1 1/8
Skit runs great and hits hard. No issues in starting, turning, pulls from idle all the way up with no issues. Twice last weekend (first weekend with engine mods) it stalled during a long wide open run. The first time was with 1/3 tank of fuel. Refilled it and rode with no issues. Later that day it stalled again at WOT, this time was at 2/3 tank.
Thinking I might have some trash in the fuel filter causing this issue.
Mods:
-Dual cooling
-Scupper
-TTO tach
-35cc chambers
-V Force 2 reeds
Main 135
Low 75
Low speed - 7/8
High speed- 1 1/8
