Super Jet Longer throttle cable
oholmes
WaveBlaster
I'm after a longer throttle cable for my superjet. I'm currently running a single carb setup, but I'm about to convert it to twin carb. The standard cable is already tight on the single carb. What throttle cables are you guys running in order to keep it mounted at the rear of the engine bay?
Vumad
Super Hero, with a cape!
St. Pete, FL
Wouldn't the dual carb need a shorter cable? The single carb is mounted in the middle of the engine. The cable hooks to the front of the dual carbs, so it's closer to the pole, requiring a shorter cable. No?
Anyway. I had a stocker with dual 38s and it broke at the throttle. I got a bigger cable from jet maniac, and a cold fusion throttle so it would fit. The cable has SBT written on it. Not sure when model, but it's about the same thickness of my kawi cables.
