- Boca Raton, FL
have had this issue for a little while. i apologize for the long post. I have a 90 sj with 701, b pipe, ada head, etc. few friends rode it and thought it was a stock ski... obviously something wrong. did a wot speed test today in completely flat water, i was only getting 25mph out of it. i couldn't stop the bow from jumping up and down constantly. Again, completely flat water where i should just be cruising right along. And i was doing everything i could to try to get it to stop and couldn't. Playing with the throttle i was able to get it a little under control for a few seconds and got a little closer to 30mph. so im missing a lot of power in the top end but im also missing in the low end. I've ridden other sj's with pretty much the exact same setup that feel way more powerful in the low end then mine. I did a compression test recently and it was 140 and 145. I contacted the person i bought the ski from and he is not sure what size domes are in it so im not sure what my compression is supposed to be. I'm going to do another compression test tomorrow to see if im losing compression, also going to do a test to see if my coil wires are shot. Other ideas of what the hell is going on would be greatly appreciated. Still new to skis so any help would be awesome. Thanks!
