WILKEY
SO FAR CHANGE SUCKS!!!!!!
Do they use a bigger bearing or can they use stock?
Here are the parts numbers for rebuilding your Yamaha or Skat-Trak Magnum pumps,
OEM 144mm Yamaha Superjet/Blaster Pump and 140/144mm Skat non-setback pumps
Bearing (2):Koyo 6205 or Koyo 6205-2RS for sealed bearing
Double lip seal (1): FP17 24.9 42 9.5 (Yamaha part number 93102-25M34)
Single lip seal (1): B11 S 24.9 42 6 (Yamaha part number 93101-25M59)
OEM 144mm Yamaha GP760/800 Pump and 140/144mm Skat setback pumps
Bearing (1):Koyo 6205 (or Koyo 6205-2RS for sealed bearing)
Bearing (1):Koyo 5205 (or Koyo 5205-2RS for sealed bearing)
*Utilizes same seals as above.
