- floatn around
Hey guys I wanted to put up a post to go through some stuff I have been researching and see if I can learn a little.
So as I have posted in other post I have recently acquired a B1 Blaster and I am going to do a ground up resto on it. I am sorting out the components I want to use for the driveline. As for motor when I do the build it will have a built motor (twin) by one of the top motor builders so it will have good power. I will of course discuss some of the driveline stuff with him including prop. As far as use this will be a lake boat for playing with the occasional running of the buoys.
The boat currently has the one piece Schredmaster intake grate and ride plate on it that I think I will keep on it.
So to start out with lets talk pumps. I will get a mag pump question is size and brand. One thing I don't want to do is any hull mods. I want all bolt on stuff. The best I can tell I can put a 148mm pump in without modding anything. But I can't really find anything that says I should go to a 148mm for any real advantage with any twin short of a 1200 fire breather especially for the lake. Any thoughts on the 144 vs 148 debate?
Then there is Solas vs Scat Trak. It appears most say Solas just deal with the bearing clearance issues during setup and your good to go. So so far I am leaning toward a Solas 144 mag unless the brain trust here can talk me out of it. The Solas is cheaper but if there were and significant advantage the money wouldn't matter.
Next up is the setback. I have acquired a JCRacing 2" pump setback kit that I think I will install. So there is that going in there too. Not sure if it will work with a 148 so more reason to stick with a 144?
Now onto stuff I know nothing about. Pump shoes? Leave it stock. Or put something else in it?
Reduction nozzles and trim? Educate me. Back in the day (long long ago) I remember always wanting trim on my Blaster. Nowadays you guys have trim on all these stand ups for doing flips and such. What kind of trim systems and reduction nozzles are best on Blasters for say running the buoys? Is it needed?
Not to leave out the midshaft. OEM or aftermarket? And the couplers. What seems to be the best?
Basically if you guys could build your perfect driveline from front to back for lake riding and some fun around the buoys what would you use?
Thanks for the input guys!
